Old 06-27-2003, 01:30 PM
metaltim metaltim is offline
Default Re: double time or halfe time some midi in PT????
cant you just make the tempo twice as fast, and the notes will move accordingly?
ive done that a couple of times I recall..
tim
Old 06-27-2003, 03:07 PM
monkey monkey is offline
Yes. That’s exactly what I've been doing too and it's so annoying. I want to be able to double time or half one element not the entire song!!! A very basic function. : ( : confused:
Old 06-28-2003, 12:02 AM
Default double time or halfe time some midi in PT????
Is there a way to take a chunk of midi, say midi to a drum loop, and double time it or 1/2 time it? NOt in 5.1 but how about 6.0?
thanks
Old 06-29-2003, 11:51 AM
LOGIC
Old 07-01-2003, 07:57 AM
WestPhillySoulzition WestPhillySoulzition is offline
Shift play. = half time
www.Subglo.com
Old 07-05-2003, 05:59 PM
<font size="2" face="Verdana, Arial">well you don't have to change the WHOLE song to ONE tempo. you can have multiple tempo shifts, as well as meter changes..
wherever your cursor is, hit the button next to the guy with the wand (on the transport window im talking), it has a 4/4 on it, and change tempo or meter.
Oh yeh, you can't be in manual mode to do this. )make sure that guy with the wand is highlighted is enbled, and you can change tempos more than once.
does this answer your question??
tim
Old 07-07-2003, 07:50 AM
NO!! Perhaps my post is not clear. Sorry. Specifically, I have a piece of midi that triggers a drum loop. I'd like to hear what that drum loop sounds like at 1/2 time or double time. I don't want to change to tempo of the entire song and I don't want to map tempo changes. I just want to effect one piece of midi. Thanks for the suggestions though.
Old 07-08-2003, 04:31 AM
steins steins is offline
<font size="2" face="Verdana, Arial">I do not know an easy way of doing this. What you can do is record the midi-loop as an audio file at double-tempo and half-tempo - shouldn't take too long. You can then mute and unmute your 3 different tracks (1 Midi at normal tempo + 2 audio tracks) to hear the difference.
Stein Tore
Stein Tore Sønsteli
Pro Tools Ultimate 2023.12 (HDX-2), Mac Studio M1 Max, MTRX Studio, Avid I/O's, S1 + Dock
Old 07-08-2003, 10:58 AM
Your right. That's the only way to do it. BOOO! : ( Thanks for the respons.
Old 05-21-2013, 01:34 PM
studios111 studios111 is offline
This is how i did it: Select all MIDI tracks and put them in "sample" mode instead of Ticks mode, now even you change the tempo the tracks won't be affected, take only the track - or part - you wanna double, change tempo half time, then put that track as well into "samples" mode, Now put back your timing and put back all tracks into "tics" mode so you can now edit them further
hope this helps
Clip Gain won’t update in real time during playback on Elastic Time tracks yanos macOS 0 06-03-2012 03:48 PM
How to Double Time (or Time Stretch) Midi? noharmlessrock MIDI 4 04-02-2008 07:32 PM
Click - Changing Sub-Divisions - Double TIme John Pisciotta Pro Tools TDM Systems (Mac) 2 03-06-2008 12:58 PM
How to double-time a MIDI region? rockridge98 Pro Tools TDM Systems (Mac) 3 05-12-2006 04:34 PM
How to make a double-time click? Dan Pinder Pro Tools TDM Systems (Mac) 13 02-06-2005 11:29 AM
