Patch preset loading issues and CPU Overload
I'm getting out of CPU power errors when I'm only at 34% load.
When I use PLAY instruments, upon opening a session, the instruments sound all garbled and nasty unless I manually play the song several times... What's up with that? SiSoftware Sandra Computer Model : OEM Serial Number : *********** Chassis : Desktop Mainboard : ASUS CROSSHAIR V FORMULA-Z Serial Number : ******** BIOS : AMI (OEM) 1901 12/24/2013 Total Memory : 15.92GB DIMM DDR3 Processors Processor : AMD FX(tm)-9370 Eight-Core Processor (4M 8T 4.72GHz, 2.21GHz IMC, 4x 2MB L2, 8MB L3) Socket/Slot : AM2r2/AM3 Chipset Memory Controller : AMD F15 (Orochi) CPU HT Hub 2x 2.61GHz (5.23GHz), 2x 8GB DIMM DDR3 1.34GHz 128-bit Memory Module(s) Memory Module : Kingston KHX1600C10D38GX 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : Kingston KHX1600C10D38GX 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : ACI ASUS VG23A (1920x1080, 24.2") Video Adapter : AMD Radeon HD 7800 Series (20CU 1280SP SM5.0 1GHz/1GHz 5% OC, 2GB DDR5 4.8GHz 256-bit, PCIe 3.00 x16) Graphics Processor OpenCL GP Processor : AMD Radeon HD 7800 Series (1280SP 20C 1GHz/1GHz 5% OC, 2GB DDR5 4.8GHz 256-bit) Compute Shader Processor : AMD Radeon HD 7800 Series (1280SP 20C 1GHz/1GHz 5% OC, 2GB DDR5 4.8GHz 256-bit) Storage Devices WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) : 466GB (E:) HGST HDS724040ALE640 (4TB, SATA600, 3.5", 7200rpm) : 4TB (F:) Seagate ST3000DM001-1CH166 (3TB, SATA600, 3.5", 7200rpm) : 3TB (C:) WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) : 932GB (G:) ASUS BW-12B1LT (6.8GB, SATA150, BD-RE, DVD+-RW, CD-RW) : 6GB (D:) Logical Storage Devices EWQL HS (E:) : 466GB (NTFS) @ WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) Hyperdrive (F:) : 4TB (NTFS) @ HGST HDS724040ALE640 (4TB, SATA600, 3.5", 7200rpm) Hard Disk (C:) : 3TB (NTFS) @ Seagate ST3000DM001-1CH166 (3TB, SATA600, 3.5", 7200rpm) EASTWEST (G:) : 932GB (NTFS) @ WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) Hard Disk : 350MB (NTFS) MAD_MEN_D2 (D:) : 6GB (UDF) @ ASUS BW-12B1LT (6.8GB, SATA150, BD-RE, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : ATI (AMD) IXP SB600/700/800 SMBUS Controller LPC Hub Controller 2 : ATI (AMD) SB700/800 LPC host controller LPC Legacy Controller 1 : T2 87-21 Audio Device : ASUS IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : MSI Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : ASUS SB700/800 SATA Controller [AHCI mode] Disk Controller : ASUS Asmedia 106x SATA Controller Disk Controller : ASUS Asmedia 106x SATA Controller USB Controller 1 : ATI (AMD) SB700/800 USB OHCI0 Controller USB Controller 2 : ATI (AMD) SB700/800 USB EHCI Controller USB Controller 3 : ATI (AMD) SB700/800 USB OHCI0 Controller USB Controller 4 : ATI (AMD) SB700/800 USB EHCI Controller USB Controller 5 : ATI (AMD) SB700/800 USB OHCI2 Controller USB Controller 6 : ATI (AMD) SB700/800 USB OHCI0 Controller USB Controller 7 : ATI (AMD) SB700/800 USB EHCI Controller USB Controller 8 : ASUS ASMedia XHCI Controller SMBus/i2c Controller 1 : ATI SB800 SMBus Printers and Faxes Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) 82583V Gigabit Network Connection (Ethernet) Wireless Adapter : 802.11n USB Wireless LAN Card (802.11g (ERP), WEP n-bit, 54Mbps) Operating System Windows System : Microsoft Windows 8.1 Professional 6.03.9600 Platform Compliance : x64 Windows Experience Index Current System : 5.9
Composer/Sound Designer Pro Tools 11 HD, 64Gb ram, 12tb SSD, 1909 HD Omni/Thunderbolt Native A bucketload of libraries www.Reverbnation.com/jedediahjenk www.soundcloud.com/jedediahjenk notedmusic.wix.com/jedediahjenk |
Re: Patch preset loading issues and CPU Overload
Also:
GUI issue here. When I minimize PT, the window cannot be restored (crashes to desktop) though it can be "previewed" via sneak peak.
No workaround found yet for GUI crashing to desktop after minimizing or CPU error.
TL Space Preset not loading | lukeyy | macOS | 3 | 06-11-2012 10:32 AM |
error loading fantom x patch names | tonedef | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-18-2008 02:11 PM |
TL Space Native-Preset Not Loading | RokVox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-25-2007 02:44 PM |
Trouble loading motif patch names. | DEMER | MIDI | 9 | 01-02-2007 08:55 PM |
SampleTank automatic loading of preset with Sessio | cd_audio_mix | Virtual Instruments | 1 | 11-25-2006 10:24 AM |
