Old 07-18-2002, 12:23 AM
Forrest77 Forrest77 is offline
Default Firewire external drive isn\'t recognized?
PIII 733Mhz, 256RAM
I installed a firewire card into my PC, then borrowed my brother's external Firewire drive which he uses on his Mac laptop.
Now aside from the fact I might need some software to open the Mac files, I can't seem to get my PC to recognize the drive. I connect the drive via the firewire cable, I have loaded the driver, the drive is on, but when I restart, the drive doesn't come up.
Any ideas? Thanks.
Old 07-31-2002, 08:19 PM
Default Re: Firewire external drive isn\'t recognized?
Any ideas?
Do I need to partition the drive in DOS first?
Where could I get the correct driver?
Old 07-31-2002, 08:34 PM
Vegadark Vegadark is offline
if you right click on my computer and go to properties > device manager... the drive will probably show up there but you will have to tell it that it is a removable device and assign a drive letter.
DIGI002R, PTLE8.0.5, Windows XP, Asus K8V SE Deluxe, AMD64 3000+ 1.5GB ram, ATI Radeon HD3xxx AGP, dual 19 inch LCD screens
Old 07-31-2002, 08:59 PM
It doesn't show up there. There is an error sign (!) which I think means it knows it is there, but it doesn't know what to make of it.
The manual said I might need to partition it in DOS, but I don't know how to do that.
Old 07-31-2002, 09:12 PM
if you partition it, you will erase everything on the drive.
Why does Avid recommend external USB over external Firewire for audio drive? DJ Hellfire Pro Tools 10 10 03-29-2012 09:39 PM
External Hard Drive Not Recognized Zach9307 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-24-2009 10:26 PM
firewire drive no longer recognized jvox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-05-2005 09:20 AM
How can you use an external firewire drive and Digi002 with only 1 firewire port? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-16-2003 01:11 AM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
