Old 08-30-2012, 01:08 PM
ChrisMac ChrisMac is offline
Default Do not import I/O settings
In Protools 7 there used to be an option when importing session data to not import session i/o. How do I do that in Protools 10. When I assemble edits into my mix template, all the i/o busses from the edit sessions come along and it totally screws up my template. I've turned off all the input/output setting options and I dont have the session overwrite i/o selected. I'm sure its something simple but I cant seem to find it??
Chris McIntosh
President/Sound Supervisor
Postal Audio Inc.
Imdb
Facebook
Old 08-30-2012, 01:41 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Default Re: Do not import I/O settings
Hey,
When you get the Import Session Data window at the bottom right there is "Track Data to Import" with a drop down list... It shouldn't import routing if you deselect "Main Output Assignments" "Send Output Assignments" "Input Assignments"
That should work
Old 08-30-2012, 04:28 PM
Nope that doesnt work, still get the assignments showing up. Maybe a bug??
Chris McIntosh
Postal Audio Inc.
Imdb
Facebook
Old 08-31-2012, 07:31 AM
Interesting...
Have you tried the normal removing pref's???
http://www.youtube.com/watch?v=Mj2fJHOz8GA
I'll test in on one of my rigs to see what happens..
Old 08-31-2012, 08:38 AM
Ok,
I have the same result.... That is not very cool... The inputs default to no input but the output assignments stay with the clip data.
I will play around with it and see what I can come up with, if anything.
Old 09-02-2012, 01:45 PM
Anyone else seeing this issue or found a work around? Its a real pain when I have a 60 or 80 buss mix template and then suddenly I have an extra 20 buss assignments import that I do not want! Maybe I ll just have to open the edit sessions and delete all the i/o settings, re-save and then do the import?
Chris McIntosh
Postal Audio Inc.
Imdb
Facebook
Old 09-03-2012, 08:18 PM
digibase digibase is offline
Is this a bug !
Old 09-03-2012, 09:19 PM
Brandonx1 Brandonx1 is offline
No it's not a bug. In the I/o set up window, uncheck sessions over write I/o.
Old 09-03-2012, 09:49 PM
Tried that. Doesn't change anything.
Chris McIntosh
Postal Audio Inc.
Imdb
Facebook
Old 11-12-2012, 12:34 PM
the hecksome the hecksome is offline
Anyone figure out how to solve this issue? Seems like the uncheck sessions overwrite i/o should work, but no luck here...
is it possible to import settings from one project to another? TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-13-2010 09:43 PM
Import mix settings Alex_C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-21-2008 12:33 PM
Import I/O settings problem? PTGuy Pro Tools TDM Systems (Mac) 2 04-03-2006 12:24 PM
Best way to import I/O settings? Lawson Pro Tools TDM Systems (Mac) 6 04-09-2005 06:31 PM
import plug in settings??? smlworld Pro Tools TDM Systems (Mac) 2 08-23-2001 12:22 AM
