Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 12-10-2020, 10:36 AM
fourthtunz fourthtunz is offline
Default Anyone tried Protools on an M1 mac yet?
I just bought the M1 MacBook air just to mess with it.
Anyone?
Old 12-10-2020, 11:05 AM
Sardi Sardi is offline
Default Re: Anyone tried Protools on an M1 mac yet?
There’s a few vids floating around of people running it on the new M1 laptops with good success.
Perhaps you can report back your findings for everyone else?
Old 12-10-2020, 01:24 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
M1 is not supported by Pro Tools at the moment
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 12-10-2020, 02:20 PM
EGS's Avatar
EGS EGS is offline
A quote from this article: "In a nutshell, we are flabbergasted at the stunning performance we are getting from Pro Tools running on an unsupported OS, via Rosetta 2 and on a chip, it's not designed for. As you can see it outperforms several higher powered machines, some of which are professional models, including the Mac Pro 6,1 and the iMac Pro." https://www.pro-tools-expert.com/pro...test-pro-tools
Click for audio/video demo
Click for resume
Old 12-15-2020, 04:35 AM
Thanks guys! I installed Protools on my Macbook Air M1 and it seems to be working fine. I played back a session from 2016 and it works fine!
Seasons Greetings!
Old 12-15-2020, 05:21 AM
arche3's Avatar
arche3 arche3 is offline
Someone try using it with an hdx card in the sonnet chassis via thunderbolt.
Sent from my SM-G986U using Tapatalk
Old 12-15-2020, 10:44 AM
tclash tclash is offline
I just got an M1 MBP (8gb ram, running Big Sur 11.1) and installed and opened up 2020.11 and started throwing stuff at it. I only had the stock plugs to work with. Started with 16 stereo tracks and put channel strip, 1176, EQ7, Massey Tapehead and 2 D-Verbs on every track, plus some mod delays here and there. Added edits w/crossfades on all tracks. Then I just started duplicating those tracks to push it. Got up to 112 tracks before it started choking (9173), and that was mostly if I swiped windows during playback.
Old 12-15-2020, 11:29 AM
Emi's Avatar
Emi Emi is offline
How’s the overall feel? And also, in the activity monitor, how’s the ram activity? Does it has to swap use (meaning it has to allocate hard disc for ram use?)
I’m planning on buying a base Mac mini m1 and since I use for basic audio recording and mixing, I want to know if 8gb of ram is enough.
Thanks
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 12-15-2020, 11:33 AM
Thanks
The feel was absolutely smooth and, dare I say, snappy. I didn't look at the swap amounts but the memory pressure stayed well within the green zone. I don't see where basic recording and mixing would be a problem with 8gb.
Overall it was really impressive on an unsupported CPU running through emulation. The only Big Sur issue I ran into was not being able to select audio files in the Import Audio window. Dragging in from Finder worked fine.
Old 12-15-2020, 12:17 PM
Emi's Avatar
Emi Emi is offline
Great to hear. Thank you!
Import session protools 8 mp vers Protools 12 [Résolue] eryck Le Forum en Français 5 10-18-2016 11:54 AM
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
changing from protools 8 audio only to protools 8 with video support djkaz macOS 5 09-04-2013 04:00 PM
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? jgbsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2011 01:08 AM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
