  #31
Old 04-22-2016, 07:10 AM
tom_lowe tom_lowe is offline
Default Re: X-form and pitch shifting
Originally Posted by MIKEROPHONICS View Post
Tom can you confirm whether it has Audiosuite?
100% yes to Audiosuite.
  #32
Old 04-22-2016, 11:15 AM
garret garret is offline
Sorry for misinformation regarding audio suite. I only have version 1.
IMDB
  #33
Old 04-22-2016, 04:02 PM
Schottlandru Schottlandru is offline
Idris, the thing with Izotope Radius is that it is only stereo at max - so phase consistency within a 5.1 mix is not given.
It did sound great in one of my tests though, and there is a thread on Gearslutz with Aleksey (an Izotope developer) giving advice on how to tweak the parameters for different artefacts.
Generally when I did a shootout I found it to sound very good on my test material, albeit only on the stereo downmix of course.
Really hoping the clever brains at Izotope find a way to go multichannel with it some time.
Mike - a shootout would be awesome!
Things to keep in mind though: 24-25 and 25-24 are two different scenarios with their own difficulties...
  #34
Old 04-22-2016, 11:33 PM
idris idris is offline
Originally Posted by Schottlandru View Post
... there is a thread on Gearslutz with Aleksey (an Izotope developer) giving advice on how to tweak the parameters for different artefacts ...
Do you have a link for that? I've tried several searches, but can't find anything obvious. (Is the spelling of his user name correct?)
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
  #35
Old 04-23-2016, 02:40 AM
Upgrade to v2 is so cheap, I'd really recommend it
  #36
Old 04-23-2016, 02:42 AM
On it Tom!! Didn't realise it was audio suite till now! Excellent news! Thanks
IMDB
  #37
Old 04-23-2016, 10:28 AM
smurfyou smurfyou is offline
I'm late to the party. I only tried X-form once and it was so slow . Timefactory is great. I've tried Elastique real-time but had no idea the new version was Audiosuite. Thanks for the heads-up!
~Will
  #38
Old 08-29-2016, 10:25 AM
minister's Avatar
minister minister is offline
Originally Posted by minister View Post
This is what I do. Except, I use X-Form. It's slow, but I have been happy with PAL to FILM or PAL to NTSC or FILM to PAL.
For NTSC to FILM or vice versa, who cares about the .1% pitch....
Some day would like to try Time Factory
Wanted to report back that I finally had an opportunity to purchase Time Factory 2 to process STEMS for a 23.976-->25 Film Style pull up. I used SRC to get everything in time. Then I put those stems into TF2 and selected the appropriate settings for each type of Stem (DX, FX, MX). I also had used X-Form to process same stems for comparison.
I must say that on every stem, TF2 sounded superior. The music stem was really good. Impressed.
HOWEVER, at an appropriate setting for music -- ZTX/Classics(l=5)/Best -- the processing time took over 5 hours. So, not FASTER. But I am happy with the results!
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
  #39
Old 08-29-2016, 11:13 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
I use TF2 all the time for all frame rate conversion tasks. Don't bather to SRC first but let the TF2 to do the job. Its especially good for 25 to 24fps conversion.
Having said that I prefer sometimes P 'n T for music stems and particularly for slow piano and strings material.
Didn't touch my X-Form for years now, even though TF2 takes time as you noticed.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
  #40
Old 10-23-2020, 11:58 PM
jyellen jyellen is offline
I'd like to resurrect this thread as it hasn't been commented on since 2016. I'm currently looking to pitch shift some 5.1 stems after doing an SRC to convert from 23.976 to 25fps. The SRC is complete and now I need to pitch back down to the original pitch.
I've tried Izotope RX 8 Time & Pitch (Radius setting) which sounded terrible. I also tried a demo of Elastique Pitch V2 which also sounded terrible. When I say terrible I mean robotic and totally unusable.
I finally tried X-Form (which I never liked in the past) out of desperation and it sounded surprisingly good on both 5.1 dialog stem and music stem; monophonic and polyphonic settings respectively.
I have yet to try Pitch n Time Pro as I can't find a demo on their site...am I missing it?
Can anyone steer me in the right direction here as to the best pitch shift plugin for audio post (specifically pitch shifting 5.1 mix stems as described above).
Thanks for your help.
System Specs
Protools 12.8.3
MAC OS 10.12.6
Mac 2010 3.46 GHz 6 Core
Thanks,
Jeff Yellen
ridgelinesound.com
HTML code is On
Pitch shifting bontay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-15-2008 10:55 AM
Time shifting/pitch shifting? mistasmijen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-31-2008 03:24 AM
Pitch Shifting danika 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-05-2007 07:15 PM
Pitch Shifting Add - On SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2006 11:09 AM
25-24 fps pitch shifting. Does anyone know? Kenan Akkawi General Discussion 1 07-23-2001 04:10 AM
