Old 07-05-2010, 11:24 AM
TDub TDub is offline
Default Recording guitar direct + guitar cab
Hey Guys,
How is the best way to record guitar track and have it going to my amp (being mic'd) as well as direct line to PTLE to have flexibility of using sim afterward?
thanks
TDub
Digi002 R with Command 8 - PTLE 8.03
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Old 07-05-2010, 11:35 AM
bmenchen bmenchen is offline
Default Re: Recording guitar direct + guitar cab
hughes kettner
is a great way to go diect its a cabnit simulator I find the mark 2 is the best one its old and hard to find but is great they have others
this way you dont have to mic anything
Old 07-05-2010, 11:50 AM
thanks for reply, but what i'm looking for is how to basically "Y" from my guitar to a) amp and b) direct to PT.
thanks though
TDub
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Old 07-05-2010, 11:52 AM
paulreed paulreed is offline
I use a direct box...countryman is nice! send the clean git signal to a pre amp and the thru to your amp. I just about ALWAYS do this (sometimes the client has no idea). pod farm is a great amp sim as is waves gtr, you can use the real amp and the sim if you want for some nice texture..
For git sounds that do not change through the piece, I sometimes don't even use an amp, my 86 prs into the Avalon 737 sounds pretty sweet and if you can't find an amp sim to suit your needs, you can re-amp....or I guess "amp" in this case.
Old 07-05-2010, 12:01 PM
Thats great! So for the clean part, go from the DI to a mic preamp, before going into my 002R? Is the preamp necessary?
TDub
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Old 07-05-2010, 01:50 PM
you can go into the pre's in the 002R! i have better pre's so i use those
if you go into the pre's in the oo2R do not use external pre's also
Old 07-05-2010, 03:03 PM
TCM's Avatar
TCM TCM is offline
As Paul said use a DI box.
I use guitar-->Radial JDI-->002R
................................!-->Amp-->mic
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 07-05-2010, 06:27 PM
Hotcrazyfruit Hotcrazyfruit is offline
Get an 11R. It records your wet and dry sounds for re-amping.
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
Old 07-05-2010, 06:36 PM
necjamc necjamc is offline
For your situation, as already mentioned, use a DI Box (I use a whirlwind) and split the signal, the parallel going to the amp, and the xlr going to the 002. That's the best way to do it.
Old 07-06-2010, 04:23 AM
Great info guys, thank you! It brings up another thought though: you mentioned don't go into pre's in 002R if using external pre. So if i use an external pre, then: a) where do i run that into on the 002R for recording? b) are the 002 pre's better than say the Presonus Blue Tube and Tube Pre single?
appreciate it as always,
TDub
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Help with guitar recording direct to DI loki01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-15-2008 02:15 AM
cheap direct guitar recording? dannypassenger Tips & Tricks 6 02-18-2005 02:33 PM
Recording Acoustic Guitar Direct Boozer007 Tips & Tricks 24 08-07-2004 07:04 AM
OT: Recording bass guitar direct Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 05-04-2004 06:07 AM
RECORDING GUITAR DIRECT fe.martin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-15-2002 01:59 PM
