Old 05-23-2014, 11:34 PM
simonyeah simonyeah is offline
Default Artiste series unlinked shift function
Hello,
When using severals artist series module (mix transport and control) do you know if it is possible to unlink shift function between units: what I intend to do is to lock Shift function on only one unit (mix for example) while keeping the other ones (transport and control) without shift function.
It would be great.
Thanks
Simon
Old 05-28-2014, 01:12 PM
Default Re: Artiste series unlinked shift function
Anyone?
Old 05-28-2014, 02:48 PM
ha2dorff ha2dorff is offline
If I understand you right: I don't think it's possible.
Why do you need to disable Shift on some of the units?
Old 05-29-2014, 09:55 AM
I am used to use d command and d control and always use the auto button on each track to punch out an automation pass (I always stay in latch). The artist mix has an auto button. I wanted to keep working like this with the artist series. Unfortunately it only works in shift mode. And I do not want to be in shift mode on the avid transport and avid control. Sad, the only solution then is I use the automatch eucon macro but saddly this one impacts all tracks being automated...
Recutting unlinked multi-mono plugs Frank Kruse Post - Surround - Video 6 03-14-2013 10:11 AM
PT9 Unlinked Timeline/Edit Selection Bug laki macOS 4 04-27-2011 03:30 PM
8.0.4 new unlinked bug? Mark the amazing guy Post - Surround - Video 2 06-15-2010 07:05 AM
Using shift function John Edwards UK Pro Tools TDM Systems (Mac) 5 09-03-2008 08:23 PM
Edit and playback markers now unlinked qbert1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-04-2007 08:39 AM
