sync 002 to time code?
hello all... i was trying to get my studio to buy a digi002 and my partners didn't want to get one because they were afraid that i could not snyc to our 2" machine via time code. is there no way to get the 002 to chase TC?? is there a TC to midi way? any ideas would be great!!
thanks, jeremy |
Re: sync 002 to time code?
You'd need a synch box like a MOTU Digital Time Piece which can chase LTC and derive an SPDIF clock.
Rail
you'd probably also need the DV Toolkit in order to display/work in timecode and feet/frames within ProTools LE.
Chaos is a name for any order that produces confusion in our mind. --George Santayana |
The DV toolkit will make it possible to see the timecode in the counter. Normally you will not need this...
What's that? - That's the machine that goes "pling". Bastiaan |
you will definately need DVD tool kit if you are going to use frames, ie:29.97 drop/non-drop, with out DVD tool kit, the time code is as follows, hour:minutes:seconds:mili seconds, so if you want to move something over 2 frams, that would be 29.97 divided by 1000 (milliseconds)which is like moving it something like 66.88 millisconds, VERY annoying and difficult
as far as time code lock up, you might want to check out Mark of the Unicorn "Unitor 8" it will take smpte t/c and convert it to midi in which you can take into PTLE.
-Mac Pro 7,1 16core 3.2GHz 96GB -OSX 12.7.2 -PTHDN 2023.12 Ultimate -HD Omni -BM Intensity Pro -Waves Mercury+SSL4000 Collection+Abbey Roads -iZotope RX10 Advanced -iZotope Post Production Suite 6 -iZotope Music Production Suite 5 -HALO UP/DOWN MIX -ANYMIX -Delonghi Perfecta ESAM 5600.S |
The Unitor 8 would only give you location (MTC) but no speed (SPDIF).. it's not a choice for chasing an analog 2". That's why I recommended the DTP which has the right capability.
Rail
Time Code out of 003 to Sync HD | M-ManLA | Post - Surround - Video | 7 | 02-23-2013 11:35 PM |
Time Code display Sync I/O | efisch | Post - Surround - Video | 2 | 07-11-2011 11:17 AM |
sync and time code | docbop | Post - Surround - Video | 3 | 07-21-2009 02:46 PM |
Generate Time Code without SYNC I/O | bgh930 | Pro Tools TDM Systems (Mac) | 8 | 07-10-2006 08:26 AM |
The best way to do video sync and time code in LE? | 16yearsjeff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 05-28-2006 02:02 PM |
