Old 01-14-2019, 02:42 PM
stevecomeau stevecomeau is offline
Default Import Session Data Problem
I used to be able to pick which tracks to import in the dialog box. None of the tracks are visible in the dialog box. Stumped.
Old 01-15-2019, 06:17 AM
daeron80 daeron80 is offline
Default Re: Import Session Data Problem
That is odd. Perhaps as a workaround, open the session you want to import from, select the tracks you want, and choose Export/Selected tracks as new session.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 02-12-2019, 04:46 PM
kcfroines kcfroines is offline
Are you trying to import surround tracks into a non-HD/Ultimate system?
Old 02-17-2019, 11:38 AM
No
Old 02-17-2019, 03:13 PM
Drew Mazurek's Avatar
Screen resolution issue? What's it set to?
www.drewmazurek.com
Old 02-17-2019, 03:51 PM
midnightrambler midnightrambler is offline
Incompatible Tools - OS version ?
Import Session Data Problem...? Nathan W. Pro Tools TDM Systems (Mac) 3 08-31-2009 03:24 PM
Problem with Import Session Data in ProTools 8 Corto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-16-2009 04:35 PM
Problem with import session data 7.1cs9? Jon_Atkinson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-17-2006 08:08 AM
Import Session Data Problem Rawbs General Discussion 1 11-10-2005 02:06 AM
Import Session Data problem scottgreiner Pro Tools TDM Systems (Mac) 1 03-30-2004 12:57 PM
