Old 06-15-2011, 02:31 PM
dmartin714 dmartin714 is offline
Default Not Normal Latency.......Help!
Ok so I have been running sessions all week, no problems what so ever, except this one session that has latency.
I lowered my buffer rate all the way down to 64, clicked the "low latency monitoring" tab, removed plug ins.....etc etc etc. All the normal fixes, but still I am having the following problems.
- When punching in a take I can hear the person singing before I've hit the punch button ( so i hear the old take and the new one below it)
- The singer is on time with the music during the recording, but when I playback they are late so I have to slide over the take to line up with the music.
Like I said, I've tried everything that usually works with latency issues, but this one is a doosey!
Running:
Pro Tools LE 8.0.5 for Windows 7 (running in XP Service Pack 2 Mode)
Dell XPS Studio i7 Core Processor, 4GB RAM
Waves Mercury
iZotope Vinyl
AiR Plugins
IK Multimedia (various plugs)
If any more info is need just ask!
Thanks
d
Old 06-15-2011, 03:19 PM
Default Re: Not Normal Latency.......Help!
Any plugins on the master fader? What are the latency readings on all your tracks(you know about the Ctrl-click on the numbers on the MIX windows strips that default to show the fader setting)?? If you see any tracks showing more than 64 samples, then probably a plugin is causing timing issues doe to its inherent latency(some plugins have little to no latency, and others have several thousand samples which can throw timing out the window)
Old 07-20-2011, 05:50 PM
the blast the blast is offline
This is exactly my issue. I have no plugins on these two bass tracks I'm trying to record. Soooo frustrating. Help???
MIDI latency NORMAL ??? corp MIDI 6 05-12-2011 07:16 PM
Is this normal 11R latency? miketeachesclass Pro Tools 9 14 11-13-2010 08:55 PM
Is This Normal? Latency Issue rhooton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-19-2005 05:07 PM
Is this normal? vlad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-01-2003 10:26 AM
Please Help!! Is this normal JWS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-08-2000 08:36 PM
