Old 05-17-2008, 07:40 AM
PSIII PSIII is offline
Default Moving part of Pro Tools to new external hard drive
I originally loaded everything on my computer hard drive. Then I kept seeing recommendations to have several things stored on an external drive to I went out and got one. I'm using a an iMac, v. 10.4.11 with a 2 GHz Intel Core 2 Duo. It has 2 GB 667 MHz DDR2 SDRAM. The external drive is a 320 GB My Book Studio edition.
My question is - what should be stored on the external drive and what is the easiest way to get it there? Do I have to uninstall and re-install everything or can it be dragged from one to the other?
Old 05-17-2008, 08:26 AM
BRH BRH is offline
Default Re: Moving part of Pro Tools to new external hard drive
Put your Session audio folders on the external. Leave the PT application on the system drive.
If you are using a Western Digital Firewire drive you will have problems with that. They go to sleep.
Old 05-17-2008, 10:24 AM
Thanks. What about the plugins in Ignition Pack 2 like BFD Lite?
Old 05-17-2008, 10:51 AM
sunburst79 sunburst79 is offline
I would leave those alone for now.
If you purchase the full version of BFD or some other intense disk streaming virtual instruments you might want to put the sample libraries on a drive(s) thats dedicated just for samples. If your just getting started with PT the Ignition Pack plugs would run best from the OS drive.
I think your better off doing it that way rather then trying to stream Audio and samples from your audio drive.
Long term you would want to have three or more disks for
OS
Audio
Samples.
If your planning on using a lot of Virtual Instruments.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 05-17-2008, 11:35 AM
Thanks very much!
Pro Tools le 8 / External Hard-drive Mixer123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-14-2010 10:37 AM
best external hard drive for pro tools? emersonrailroad Pro Tools M-Powered (Win) 4 02-08-2008 02:58 PM
External Hard Drive for M-Powered Pro Tools MED3KONN Pro Tools M-Powered (Win) 9 12-01-2006 06:10 PM
external hard drive set up with Pro Tools fmbighair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-23-2006 02:26 PM
Help with External Hard Drive for Pro Tools!!! Humbubinc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-07-2004 02:36 AM
