DAE Error 728, when connecting AVID Mojo
so now that 7.4 is supposed to work with the mojobox i am getting DAE-error 728, once i connect it.
Will LE7.4 only work with mojo sdi? Our box doesn´t have sdi, nevertheless it is updating the firmware. I am hoping on the first CS - please! |
Re: DAE Error 728, when connecting AVID Mojo
I'm having the same problem with the MOJO SDI.... Both the MOJO and mbox2 will work together, but not once I try to use the DIGI 002 and MOJO SDI...
I've tried this on tiger 10.4.11 and Leopard 10.5.1 with same results.. MBP Core Duo 2.0Ghz 2.0GB RAM Daisy chain from MAC to DIGI 002 to MOJO SDI... Is there a solution here? or do we have to wait for the Leopard update? I wonder if getting an ExpressCard firewire card could solve this. Maybe too much information on that single firewire bus. HELP DIGI.....!!!! |
I've got the same issue.
PT7.4 10.4.11 002 Mojo Running an Imac 2Ghz Intel core Duo w/3GB Ram |
Everything i've ever known about the Mojo suggests that it needs its own firewire bus.
Working With Avid Mojo - Avid QT LE Codecs | SPC | Post - Surround - Video | 7 | 07-22-2009 02:41 PM |
Avid Mojo SDI | King of Spain | Post - Surround - Video | 15 | 08-12-2008 09:57 AM |
Avid Mojo SDI | MusoPro | Post - Surround - Video | 13 | 02-15-2007 07:31 PM |
AVID MOJO / AVID XPRESS DV / PT 7.0 Questions | Echo studios | Post - Surround - Video | 5 | 01-07-2006 12:06 AM |
Avid Adrenaline to Avid Mojo | uno1234 | Post - Surround - Video | 4 | 06-11-2005 07:11 AM |
