Old 10-30-2018, 08:13 AM
imjtblanton imjtblanton is offline
Default Sound Missing in Premiere AAF, OMF Import
I sent out both an AAF and an OMF from Premiere Pro to Pro Tools. I opened it in Pro Tools. All of the clips show up and it does not say any of them had problems linking. All of the clips have their appropriate waveforms. But when played about half of the clips simply produce no audio. I can see the waveform. And the bars that show the peaking (whatever they're called) jump up and down as it plays through the audio. But no sound. I sent it through a BUS and printed it onto a STEM and no audio makes it to the BUS or gets printed.
What could be causing this? It happens with both the AAF and the OMF, but the silenced clips appear to be different.
Old 10-30-2018, 09:28 AM
KingTor KingTor is offline
Default Re: Sound Missing in Premiere AAF, OMF Import
I would imagine you've checked the volume automation. Sometimes I get projects from premiere that the editor has boosted by more than 12dB that somehow translate to -[infinity].
sent from a stupid phone using Tapatalk
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 10-30-2018, 03:58 PM
It looks like the automation was the problem. I imported the AAF and unchecked "Import Volume Automation" and that fixed it. But I did a good deal of basic volume automation in Premiere and would not like to have to do it all over again. Is there any way to import with the volume automation intact?
Old 10-30-2018, 09:04 PM
In my experience all of the Premiere automation IS intact EXCEPT for the clips which were boosted by more than 12dB, and those can be trimmed on the volume graph of Pro Tools up to 12dB and then boosted further using clip based gain. It's a PITA, but better than starting with no automation IMHO.
HTML code is On
OMF import from Premiere cs6 into PT 10 problem bebeuriarte Windows 3 09-28-2013 03:06 PM
OMF import error from Premiere Pro 6 PT11 HD IMLaudio Pro Tools 11 0 06-25-2013 09:14 AM
Import audio from Premiere Pro 2.0 Flaf Post - Surround - Video 0 01-06-2007 11:31 AM
AAF Import from Premiere FlorianE Post - Surround - Video 6 07-28-2006 06:24 AM
Premiere export - Pro Tools import Stig Eliassen Post - Surround - Video 8 10-27-2005 09:04 AM
