Old 05-08-2018, 02:07 AM
dezst dezst is offline
Default Re: Greyed out tracks and regions in Edit Window
Originally Posted by rossi68 View Post
I got the same problem, starting a few weekas ago.
I go to the I/O setup, uncheck all bus routing, click ok,
Then open I/O setup again and check the first bus routing option-click ok.
Then its normal again, at least on my system.
Win 10, PT 12.7
RME fireface UFX
Thanks, I'll give that a go next time it happens. At the moment I clear the problem by duplicating the frozen track, deleting it and then using the new one.
Pro Tools 2018.12.0 with Duet by APOGEE
M-Audio Keystation 49e
iMac 27-inch - Late 2015 - 3.2GHz - Intel Core i5
32 GB 1867 MHz DDR3
macOS Mojave v10.14.2
AMD Radeon R9 M380 2048 MB
Old 05-09-2018, 05:04 AM
vinylzool vinylzool is offline
Hello. I am having a similar problem except everything is playing back so it's not an I/O issue. This happened after I duplicated the project and made a copy. Now when I go back to the original, or any previously saved versions all tracks are greyed out and uneditable. I have tried all the fixes mentioned so far in this thread. I also upgraded to the latest version of Pro Tools. Is anyone else having this problem? I literally can't work On this song or find a work around. Any help would be much appreciated.
- Chris
Old 11-11-2018, 07:31 AM
wrek wrek is offline
- Chris
I had a similar issue when I tried to connect a midi keyboard to my Eleven Rack. I had to change playback engines because my Omni doesn't have midi.
When the midi didn't recognize my keyboard, I resorted to playing the keyboard live to an audio track, and disconnected the midi cables. When I reopened the session the next day, all of my new tracks were greyed out, but audible.
I put all of my I/O settings to default, but the tracks were still grey. Then, I trimmed the end off one of my greyed tracks and suddenly it turned to color.
I did the same to all of the other grey tracks, and it worked.
greyed out regions in tracks urumita Pro Tools TDM Systems (Mac) 6 02-21-2024 05:57 PM
No Color in the Regions in the Edit Window lou_natic Pro Tools 10 1 06-04-2015 10:46 PM
Gap between edit window views and regions synth999 Pro Tools TDM Systems (Win) 2 04-26-2011 11:26 PM
OMF regions don't appear in Edit window muses Post - Surround - Video 2 02-06-2011 11:08 AM
Color coding regions in Edit window? nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2001 01:37 PM
