Old 12-15-2012, 02:05 PM
michaelrowe michaelrowe is offline
Default Unable to locate Avid hardware
i keep getting this message when trying to turn it on the first time. dos anyone know how to fix this?
Old 12-15-2012, 03:15 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Unable to locate Avid hardware
More info needed....
What OS?
Which Interface..Firewire/USB?
What version of Pro Tools?
Have you installed latest relevant drivers?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 12-15-2012, 03:33 PM
cwsand's Avatar
cwsand cwsand is offline
Help us Help You - READ THIS Before Posting!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 12-15-2012, 04:48 PM
DigiTechSupt's Avatar
Post Re: Unable to locate Avid hardware
Also... using the Search The Knowledge Base link (near the top of the DUC) to look for the title of your thread should provide some helpful info.
Avid Audio Tech Support
Support FAQ
Old 12-16-2012, 09:26 PM
Southsidemusic's Avatar
Turn what or Who on the first time? If it is a girl you will need some smooth moves to turn her on and if you are talking about your computer and anything Avid you need to have the same skillz there too
Good Luck! I an gonna go turn on my girl now!
She is a good looking silver box called Mac-sie
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-17-2012, 08:44 AM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
If your having problems getting Pro Tools to launch with your hardware (say the hardware is new or software install is new) you can hold down the "N" key when you launch pro tools... a splash screen opens up and you can select the hardware in the top drop down menu. Then press ok and it will launch using that hardware.
If your hardware doesnt show up you need to install the correct drivers, restart and do the same thing... once you get the hardware to show up in the dropdown you should be up and running,
Unable to locate Avid Hardware fosterfreeze Pro Tools SE and Essential (Win) 7 03-05-2014 09:59 AM
Unable to locate Avid hardware. Avid Pro Tools SE 8.0.3 (M-Audio KeyStudio 49) azndisast3r Pro Tools SE and Essential (Win) 3 09-21-2013 02:31 PM
Pro Tools SE unable to locate Avid Hardware error WIN 8? joe979xx Pro Tools SE and Essential (Win) 2 07-25-2013 11:37 AM
Unable to locate Avid hardware... torrror Pro Tools SE and Essential (Win) 0 05-28-2012 03:23 PM
AVID SUPPORT - DIGI002 CONSOLE - Unable to locate Digidesign Hardware bdeivert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-01-2011 04:21 PM
