Old 07-18-2017, 11:58 PM
tonyreed tonyreed is offline
Default Changing tempo in Pt12.5
Im after some advice on how I might increase the tempo of my song by about 5 bpm. I have a number of tracks recorded that I dont want to have to re do. I am assuming that elastic audio is used for this but its not obvious to me how to use it. Thanks Tony
Old 07-19-2017, 05:33 AM
Sardi Sardi is offline
Default Re: Changing tempo in Pt12.5
If you've already got a tempo assigned to your track, then simply enable EA on all the tracks, set them to tick based and then type the new tempo in and like magic everything will be slightly faster.
Then spend countless hours tweaking the EA settings on each track so that it sounds decent.
BTW, if you didn't assign a tempo before recording, just select a few bars and use identify beat to get the tempo.
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 07:58 AM
Tap tempo and involuntary time shifting with tempo changing Skiroy Pro Tools M-Powered (Win) 3 08-26-2010 11:00 AM
changing tempo without changing pitch Sharabelle Pro Tools TDM Systems (Mac) 3 02-10-2007 06:19 PM
Changing tempo in manual tempo mode guentherschmidt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-28-2006 09:52 PM
Changing tempo w/out changing midi performance??? toddm7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2005 11:35 AM
