Old 07-05-2016, 12:51 PM
Goombot Goombot is offline
Default Protools 12.4 not passing audio
Has anyone had this? This only happens with the top bank of 8 or so in a session. So whatever is on top of my session. It has nothing to do with the outputs, the I/O. I'll play a session, the track will un-muted, audio will not play. I close the session, quit PT, open PT, open session, hit play and the audio is there. I thought I could make a work around by creating 8 blank tracks, putting them at the top of the session, but nope. That doesn't work. It doesn't have anything to do with my output card because I'm always hearing 1 and 2. I've also had this in reverse where a track is muted and it plays. I do the same thing, quit, launch, hit play and then you can't hear it. I have both of these examples on video. It happens multiple times a day. Again, another reason PT12 is a disaster.
Old 07-05-2016, 12:58 PM
Default Re: Protools 12.4 not passing audio
My first suspicion would be a messed up or corrupted session. Does this happen in all sessions? In new empty sessions?
Have have tried trashing prefs and deleting and defaulting input, output and bus?
Old 07-05-2016, 12:59 PM
Happens in all sessions. Haven't trashed prefs in awhile. My template is a monster so I can't just redo it.
Old 07-05-2016, 01:02 PM
Well trashing prefs is one of the first things you need to try. Save copies of the files in case it does not help. (Pro Tools prefs helper makes it easy to back them up in case it does not work.)
And default all that IO.
Nobody else is reporting anything like this so I very much suspect it is just something with your setup, and it sounds very much like a session/IO corruption issue.
Old 07-05-2016, 01:03 PM
yeah I'll try it
Okay,I gave up on my 002.My 003 is not passing audio through when using LLM in PT 10 studiostrat macOS 0 01-11-2014 01:15 PM
No audio passing through Mbox2 Pro wrkingclassoi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-29-2008 12:43 PM
core audio conects , but no audio passing threw audiomania Pro Tools TDM Systems (Mac) 2 08-23-2006 08:41 AM
busses not passing audio WTF!? jash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2005 07:41 PM
882/20 input not passing audio Craig Woolard Pro Tools TDM Systems (Mac) 1 07-17-2000 11:51 PM
