Old 11-30-2015, 09:48 PM
jf.burman jf.burman is offline
Default New waves central crashing Pro Tools 11
I've just installed the latest version of Waves Central, which forced me to re-install all my waves plugins, and now Pro Tools is crashing when I start to use some Waves plugins in a session.
Does someone else experience this problem?
I'm running Pro Tools 11.3.1 on a PC with Windows 7 installed on an SSD.
I tried to go back to a previous version of Waves Central but the installation always fails at the beginning...
Thanks in advance for your help
JF
Old 12-01-2015, 12:04 AM
ChazC ChazC is offline
Default Re: New waves central crashing Pro Tools 11
Pro Tools has to be one of the most infuriatingly fussy pieces of software in existence when it comes to plug ins.. I've just had a nightmare with plug ins in PT12.
As long as you've already tried trashing prefs & db's, I suggest you remove all your 3rd party plug ins except Waves (just move them out of the Plug Ins folder) and see if PT will then start.
If it does, start adding back your other plugs a few at a time until you find the culprit(s). Then check to see if it's the latest version. Update it if not & try again.
I can't load half of the Plug & Mix plug ins due to an incompatibility with IK Multimedia stuff in PT12 (which all worked together fine in PT11). An out of date Metaplugin was also giving PT12 fits. Everything was still fine in Cubase, Studio One & Reaper. AAX is the culprit format.
Good luck!
{edit} Sorry, just re-read this. PT actually boots up OK then - it's during operation. I'd still bet it's an out of date plug in somewhere conflicting with Waves.
Chaz
Shifting Sands Audio
www.shiftingsandsaudio.com
soundcloud.com/shiftingsands
Asus X79 Deluxe | i7 4930K @ 4.1 | 32Gb Ripjaws CL9 GBLZ | Radeon R5 230 | Win7 Pro (64) | 256Gb Samsung 850 SSD | 2x 1Tb Seagate SATA | 250Gb Samsung EVO SSD | 128 Samsung SSD | Antec 650W | ProTools 11.3.2HD, 10.3.9HD, 12.5 | Cubase 9.0.20 Pro | Nuendo 8 | Studio One 3.2 Pro | RME UFX | 2x Octopre Mkii Dynamic | Alphatrack | DTouch | Logitech G510 | Kensington Trackball | Yamaha UX256
Old 12-01-2015, 05:51 AM
I was a bit nervous when I installed Waves Central when I got the freebie TruVerb this weekend. It installed and has run just fine with no glitches on my OSX 10.9.5 partition and running PT11.3.1. I also installed it but haven't yet tried it on my OSX 10.8.5 partition and either PT10.3.1 or PT11.3.1 so can't comment on that. What I like is you don't have to download the whole Waves shebang if you only want a single plugin or two. You just download what you need and that's it.
Jack
QAPLA!
Old 12-01-2015, 01:53 PM
I deleted the "WaveShell-AAX 9.2" and 9.3 folder while leaving the 9.6 folder in the plugins folder and it seems to go well now.
Thanks!
JF
Old 12-02-2015, 08:53 AM
I take off what I just said... it started again after a couple hours.
Old 12-07-2015, 09:57 AM
Anybody esle had this problem?
Old 12-08-2015, 07:17 AM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
I've seen a lot of people with this issue.
There were a couple versions that they've released now that won't coexist with previous versions. AND, there are some waveshells that will cause issues if they are coexisting.
Here's what I have been doing since the beginning of the v9 days.
1) Move licenses to cloud.
2) Run Waves Uninstaller and kill everything
3) Manually remove pref's/caches and any lingering waveshells
[preferences, databases, plugins folders - vary by OS]
4) Reboot for good measure
5) Reinstall everything you need
6) Put licenses back on your machine
This works for me, and even with Mercury and SoundGrid Studio, I can do all of this in about 15 minutes. So, not a big deal.
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Waves Central K.I. AAX Plug-ins 62 01-01-2016 08:52 PM
Waves crashing PT? gutterfly Pro Tools 10 10 08-13-2015 01:12 AM
Waves 8 Crashing Pro Tools 9.0.3 espennor Pro Tools TDM Systems (Win) 0 09-27-2011 03:28 PM
Waves a crashing natural 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-05-2009 09:49 AM
Waves SSL TDM Crashing PT7 caustic Pro Tools TDM Systems (Win) 11 03-19-2006 08:07 PM
