Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 08-19-2010, 12:17 PM
bfreshmoney bfreshmoney is offline
Default "unable to locate m-audio hardware. Make sure device is connected and powered on"
Hey, I spent (hopefully not WASTED) $100 on this so I need an answer already. The phone support guys don't help thy tell me to go here. I am running windows vista home premium 32-bit. everytime i open pro tools the error message pops up "unable to locate m-audio hardware..blahblahblah"....please help me, i have uninstalled and reinstalled....i know the device is connected HELPP
Old 08-31-2010, 11:19 AM
AMDK7 AMDK7 is offline
Default Re: "unable to locate m-audio hardware. Make sure device is connected and powered on"
This has been an issue with mine as well. I am using win7 64 bit, and sometimes have to un-plug and re-plug the usb cable to the device. Normally, with the first pop-up dialog that comes up, re-connect the device then click the "OK" button. Pro-tools should then recognize the device and load properly.
its kind of frustrating, but this is the first piece of hardware that I have been able to connect to a PC and actually be able to loop-record! So any small inconvenience can be easily overlooked at this point.
Old 08-31-2010, 11:35 AM
DigiTechSupt's Avatar
There's a Pro Tools Essential FAQ at the top of this forum - you should take a look at it, as it addresses the vast majority of issues you could encounter with Essentials, including the 'unable to locate hardware' problem.
Here's a direct link to that portion of the FAQ:
http://www.m-audio.com/index.php?do=...9743384fc12272
Avid Audio Tech Support
Support FAQ
Old 09-01-2010, 07:38 AM
Yeah so I just did a clean factory reinstall of vista, upgraded to service pack 1, and installed pro tools. it works fine now. but im still a little upset that i cant save any mp3's =(
'Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o roland342 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 10:01 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 01:59 AM
Solution: "Unable to locate M-Audio Hardware..." Pro-Tools 8.0 M-Powered on 64 bit OS bnorrgar Pro Tools M-Powered (Win) 6 06-26-2012 01:02 PM
Error "unable to locate hardware. make sure your hardware is connected and turned on" tmcgrechan Windows 2 10-06-2011 10:12 AM
Axiom 49, Pro Tools M-Powered 7.4 CS2 : "Unable to locate M-audio hardware" Sleightmind Pro Tools M-Powered (Win) 9 08-15-2008 08:07 AM
