Old 12-25-2008, 12:23 PM
MEAT MEAT is offline
Default Air plugins DAE ERROR 7054
90% of the time this is what I get when trying to use the Air plugs.Once in a blue moon they will appear.All my other plugs work fine.What gives digi?
Bug ridden Pro Tools 8 but back to 7.4 HD2,192 I/O,96 I/O,Midi I/O,Control 24
Old 12-25-2008, 01:08 PM
Default Re: Air plugins DAE ERROR 7054
Update:Now add Structure and Eleven tdm to that list.WTF IS GOING ON???
Old 12-26-2008, 02:14 AM
psmworld's Avatar
psmworld psmworld is offline
delete your prefs folder.
Selling:
Old 12-26-2008, 05:43 AM
I did that 6 times along with 6 reinstalls.
My last effort will be a reinstall from the download on the digi site..........i've been using the hard copy and it might be corrupt somehow.That's the only thing I can think of.
Old 12-26-2008, 04:09 PM
psmworld's Avatar
a reinstall won´t help if there are still files of an older PT-version where it will keep the old ones and won´t install the new 8.0 ones. could be some dll that has something to do with the plugins.
i recommend a clean xp/vista install and all plugins on the newest versions.
Selling:
Old 12-26-2008, 07:07 PM
Air plugs started giving me runtime errors and non of my instruments would load............always giving me a DAE 7054.I went back to 7.4 and everything runs as smooth as a baby's *****.Calling my Sweetwater rep in the morning and demanding a $250 refund.Considering I spend well over $5,000 a year at their store I expect a full refund.This PT8 upgrade is the biggest failure in digi's history imho.My clients can not wait for digi's f#ckups.From PT6-7.4 has been totally stable.PT8 is a nightmare and it ain't the fault of my pc either.7.4 never gave me 1 issue whatsoever and PT8 should be the same if digi knew what they were doing.Cheers!
Old 12-26-2008, 09:25 PM
DigiTechSupt's Avatar
Have you tried installing the latest PACE drivers? What about testing from a different admin account? This error is usually related to authorizations not being correct...
Avid Audio Tech Support
Support FAQ
Old 12-27-2008, 07:43 PM
OK........I downloaded PTHD8 from digi's site.I was using the boxed dvd version bought from Sweetwater.I installed the download and now everything works like it should.What gives??? Was/is my dvd corrupt?
I did notice that from the digi site download that Structure free was installed and my full version of Structure did not show up in PT8 as to where my dvd install it told me that since Structure was already installed that it would not install Structure free.
I just moved Structure free into my unused plugins folder and reinstalled my full version of Structure.3 hrs of testing and rock solid so far.
dae error 7054 C V MUZIK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2013 12:52 PM
-7054 for Audio Suite plugins Vedat macOS 0 02-14-2012 04:33 PM
DAE error #7054 while loading pre-installed plugins (air) Renich Pro Tools M-Powered (Win) 0 07-08-2009 02:15 PM
DUY TDM Error -7054 yoontek Pro Tools TDM Systems (Mac) 0 02-16-2008 03:20 PM
ERROR # 7054 jeffinmarin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-10-2002 07:22 AM
