Old 08-22-2008, 05:52 PM
SweetSoulSound SweetSoulSound is offline
Default recording with phantom power *and* without phantom power simultaneously
Hi, Everyone-
Hoping to get some helpful "how to" info. Here's my situation:
I have two mics, an AT4047 and a CAD Trion 7000. What I want to do is record my saxophone playing while printing both mics at the same time (à la Joe Ferla, Rich Breen, et al.).
My problem is that I'm running a Pro Tools LE 7.4 Mbox2, and the AT4047 needs phantom power, whereas the CAD Trion 7000, being a ribbon mic, would be damaged by phantom power. I can only turn phantom power on globally for both Mbox inputs, not just for one input only.
I also have a Mackie 1402-VLZ mixer (which has phantom power). I'm wondering if there's some good way to use the mixer in combination with the Mbox in order to use both mics at the same time while feeding phatom power to one mic and not the other.
Many thanks in advance to everyone for any help/advice you can offer.
~Arun
Arun Luthra - saxophonist, composer, arranger
www.ArunLuthra.NET
myspace.com/arunluthra
cdbaby.com/cd/arun
Old 08-22-2008, 06:23 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default
Hi Arun,
Welcome to the DUC.
I haven't had much experience with ribbon microphones, but I would assume that the following setup would work.
Plug your CAD into input 1 on the Mbox2 with no phantom power. Plug the AT4047 into the Mackie, using phantom power. Then send it either to the main left channel, or to one of your aux outs. Run a 1/4" cable from that output to the other (line) input on the Mbox2.
I've never done this with your setup, but I would think it should work just fine. There may be some better suggestions out there, but that's all I got. Good luck.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 08-22-2008, 06:25 PM
flommer flommer is offline
Default
Use the AT via the Mackie(with Phantom) > Mbox
Use the ribbon via the Mbox (no Phantom)
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 08-22-2008, 07:21 PM
Hi, Ryan Young and flommer-
I just now went ahead and tried what you both suggested (thanks for the specific instructions, Ryan), and it worked great! The Trion 7000 and the AT4047 really complement each other well and bring out the best qualities in a tenor saxophone. I'll try it with soprano next.
Thanks again!
~Arun
Old 08-22-2008, 07:40 PM
Pepo Pepo is offline
Default
Also, if it is a portable set up, you could just buy a phantom power box to use with the AT and skip the mackie altogether. I dont know about your mbox, but if the line ins cant bypass the mic preamp circuit, you will run the signal thru 2 preamps, wich may not sound very clean.
Or maybe try the mackie for the ribbon.
Good luck
Pepo
Phantom Power bonzerboy General Discussion 19 06-19-2011 08:43 PM
002R Faults + power harness + no phantom power DaveSB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2009 01:10 AM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
Phantom power problems and recording levels jons 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-10-2004 08:07 AM
001 and phantom power billy101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 11-19-2003 08:55 AM
