Old 07-09-2006, 02:27 AM
Lizardpoint Lizardpoint is offline
Default C24 Schematic wanted - Monitor issue....
Hi Team,
Has anyone out these got a schematic for the Control 24 ?
A PDF would be easiest, however I will pay for copying charges and post if you have a paper manual.
I am so disappointed with the monitor section audio path that my play is to design an "Upgraded" board with a significantly quieter signal path.
I have Genele 8050's connected to my C24 and the hiss from them is plainly unacceptable. As soon as I disconnect them, they are silent.
The headphone output is perfectly quiet, so why aren't the monitor outputs.
I have changed the audio board, monitor board and the power suply and have only had a monor improvement.
And don't get me started on the monitor volume control. This is being used as a very low resolution encoder so that a 6 gang (For surround sound) volume control was not necessary.
This results in a stepping of the volume rather than a continuous variation as with a conventional control.
Trying to check mixes at low volume is a joke as I can only choose between step 1 and step 2.
And the volume doesn't go to zero when the control is at zero either..
I have an audio engineering background and would like to do this for me, although I would make the board available to all C24 users if it is financially viable.
For my needs, the C24 is perfect. I just want to be able to use all of it and not have to buy a monitor contorller too.
Not much to ask given the price...
Anyway, rant over.
Anyone help me out with a schematic so I can get started?
Cheers
Lizardpoint
Old 02-12-2008, 09:05 AM
jeffredefer jeffredefer is offline
Default Re: C24 Schematic wanted - Monitor issue....
Did you ever find a schematic for the Control 24? I could sure use one too.
Old 02-15-2008, 10:22 AM
No luck I'm afraid.
I think when you become a Digi service agent you have to memorise the schematics of all the equipment.
I'll keep looking though...
Lizardpoint
Old 02-21-2008, 07:14 AM
Stiwdio Bos Stiwdio Bos is offline
Oh no... I'm really depressed to hear that digidesign went to all that trouble to dssign a new controller and faltered badly at the last hurdle. I've just got my c|24 up and running only to discover a completely unacceptable hiss in my mackie 824s.
what can i do other than get rid of the console?
HISSterically....!
make good records not war...!
Gwyn
Old 02-21-2008, 06:09 PM
BradLyons BradLyons is offline
Do you have the Control24, or the new C24? You made reference to both, so just wondering. As to these control surfaces, I currently have (2) Control24's---one in the HD studio at my church and the other in my personal HD studio at home, both rooms have ProTools HD3 Accel systems. Personally, I'm using a Presonus Central Station in both rooms directly out of my DAC. This gives me more routing capability, headphone cue inputs and more input to output references. And well I have to say, a better monitor bus. Plus, everything is available with standard TRS jacks in a single space rackmount.
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Schematic for Balanced Passive Monitor Control... Archmart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-03-2005 11:52 AM
Wanted: Schematic for Aardvark Q10 mic pre/convert Jahz Pro Tools TDM Systems (Mac) 0 05-07-2005 03:15 PM
monitor opions wanted russell jack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-06-2004 03:43 AM
Advice Wanted for LCD Monitor Purchasing relaxo Pro Tools TDM Systems (Mac) 6 06-05-2003 11:03 AM
Schematic for 001?? Doc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-08-2001 09:30 PM
