Old 10-03-2005, 08:02 PM
gitan gitan is offline
Default Low latency monitoring with virtual instrument...
Is there anyway to work around the fact that virtual instruments like trilogy and atmosphere are automatically in "bypass" mode when PT is in low latency monitoring mode. For me, the latency in non-low latency mode is so bad that I can effectively lay down a part. Is there any way to take it our of bypass--or is there a workaround? Any help will be greatly appreciated!
I have PT 002 with a 3Gig PC, 1 Gig Ram.
Thanks!
Old 10-03-2005, 08:24 PM
Default Re: Low latency monitoring with virtual instrument
I can't tell from your post - are you talking about using LL mode for actually playing the virtual instruments, or for tracking analog sources while virtual instruments are being played back?
Low latency mode is only for monitoring analog inputs. For lowest lag while playing virtual instruments, your only option is to use the lowest possible setting for HW buffer.
If your virtual instruments are being bypassed by LL mode, try assigning the inputs on the AUX channels(which aren't really used) to something other than an analog input, such as a bus.
Quad 2.5 G5, 4.5G RAM
Old 10-03-2005, 09:43 PM
yes, I am talking about actually playing the virtual instruments. I tried to adjust the buffer size, but there is still quite a noticeable lag...
Virtual instrument latency -- not! DAWgEAR Pro Tools HDX & HD Native Systems (Win) 2 06-14-2013 11:48 AM
Virtual Instrument help! madgt621 Virtual Instruments 2 04-06-2010 06:57 AM
Lag when using virtual instrument... onebigtrip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-22-2008 11:47 AM
Virtual instrument latency problems!!!!! ScottFB Virtual Instruments 6 07-23-2007 10:22 AM
virtual instrument latency joelsimone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-18-2002 09:19 AM
