Old 07-02-2006, 09:47 PM
Eric Gale Eric Gale is offline
Default Pro Tools hanging on startup at \"Loading Plugins\"
I am using Pro Tools 5.3.1 on a Digi001. I downloaded the trial version of Autotune a while ago and it timed out.
When I start Pro Tools now, the software hangs at the "Loading Plugins" stage with the "Auto Tune 4 RTAS-5.dpm" filename visible on the screen.
At this point, I can't do anything because the software stops at this screen.
Is there a way to keep Pro Tools from trying to load this plug-in at startup?
How can I get this working without a complete re-install?
Thanks,
Eric
Old 07-02-2006, 10:40 PM
dmm dmm is offline
Default Re: Pro Tools hanging on startup at \"Loading Plugins\"
What version of Windows are you running?
try this
That link came from the general trouble shooting thread.
Hopefully that info will work with 5.3.1.
Good Luck.
Old 07-02-2006, 11:20 PM
KingFish KingFish is offline
Remove BOTH (if there are 2 *.dpm and *.rsr) Antares Auto-Tune plugin files, from C:/Program Files/Common Files/Digidesign/DAE/Plug-Ins folder, and Pro-Tools won't load that plugin when launched.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 07-03-2006, 07:35 AM
Hey,
I am using WIn XP.
It worked! Pro Tools is loading.
Thanks,
Eric
Pro Tools 11/10 hanging on startup, crashing Mac Pro :( spmusik Pro Tools 11 4 07-19-2013 06:19 PM
Pro Tools LE 8 hanging on startup with VocalignLE - WIN 7 RC otobot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 11-01-2009 01:32 PM
Pro Tools LE 7.4 hanging on startup vlepore VENUE Live Sound Systems 1 10-11-2009 02:31 PM
PT LE8 Hanging On first Startup steevo605 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-08-2009 02:45 AM
ilok plugins not loading on startup? 8trackmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-23-2006 04:40 PM
