Old 09-07-2010, 07:28 AM
manonash manonash is offline
Default Re: BASIC BOOM Question.. Please Help.
...and a related question: I have a couple of tracks that got a bit hosed during editing. They play just fine, but if I attempt to Consolidate Region for all pieces of the track(s), the audio gets fouled up around the splices.
Is there some way I can pipe the audio to a new Audio channel and record it there in one piece. I tried setting the output of the non-consolidatable track to a bus, then setting the input of a new audio track to that bus, but again I get no audio on the new track.
Thanks.
Old 09-07-2010, 03:34 PM
gdugan gdugan is offline
Originally Posted by manonash View Post
...the Instrument track output is set to Bus1-2, the Audio track input is set to Bus1-2, and the Audio track output is set to Output1-2. But I get zilch...
Did you record-enable the Audio track?
...and a related question: I have a couple of tracks that got a bit hosed during editing. They play just fine, but if I attempt to Consolidate Region for all pieces of the track(s), the audio gets fouled up around the splices...
Did you crossfade all your splices?
...I tried setting the output of the non-consolidatable track to a bus, then setting the input of a new audio track to that bus...
That should work. Again, did you record-enable the Audio track?
Old 11-17-2013, 01:47 PM
sharp11 sharp11 is offline
I thought sure this was going to solve my problem, and apparently is has solved others' problem -- but when I do this I get no audio on the Audio track. The Instrument track volume meter shows the drum kit banging away, the Instrument track output is set to Bus1-2, the Audio track input is set to Bus1-2, and the Audio track output is set to Output1-2. But I get zilch.
Anybody have an idea?
Thanks!
(ProTools 8.03)
Make sure the volume is up on the send - to do this as a shortcut, hold down the option key and click on the volume slider - it will snap to zero db.
BOOM Question mrmosquito Virtual Instruments 8 09-30-2010 07:22 PM
Boom question stainless Virtual Instruments 1 08-11-2010 07:37 PM
Question about Boom... Darkostica 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-27-2009 11:06 PM
Basic, basic recording question enigami MIDI 1 06-08-2009 06:27 PM
Basic Pro Tools use. Really Basic question. Shizznik_McRuube 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2002 11:41 AM
