Old 01-14-2011, 12:06 AM
New Dimension Studios New Dimension Studios is offline
Default Pro Tools 9 & AIR Plugins
Every time I try to insert any of the AIR plugins on a track, I get a beachball and pro tools freezes. All other plugins work great. I've repaired permissions, deleted preferences, and performed a clean install of PT9 but still same result. This is without any interfaces connected. I'm running a MacBook Pro 2.4 GHz Core 2 Duo, 4GB Ram, OS 10.6.5. & PT 9.0.1.... any suggestions?
Old 01-14-2011, 09:16 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Pro Tools 9 & AIR Plugins
Originally Posted by New Dimension Studios View Post
You are using the "full" installer? and not the upgrade installer!
And you are installing Pro Tools for the first time and not installing on top of an old version !!!
Maybe try running the 10.6.5 combo updater for SL
Should work fine of course!
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-14-2011, 04:42 PM
Hi Chris,
Thank you for the response.
This is the first time Pro Tools is being installed on the Mac. I'm using the new full installer of 9.0.1.
Everything else works perfectly... Very weird.
Thanks,
Kevin
Old 01-14-2011, 08:58 PM
Craig F Craig F is offline
check the permissions of the AIR plugs in the Plug-Ins folder
I haven't seen a problem lately but I use to in OSX 10.2
Thank you,
Craig
Old 01-15-2011, 01:49 AM
crizdee's Avatar
Hi Chris,
Thanks,
Kevin
9.0.1 is an update!! You need to install PT 9 full installer before 9.0.1
Run the uninstaller first then trash prefs and re-boot before running re-installing pt9 full then 9.0.1
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-15-2011, 03:32 PM
AxeDye AxeDye is offline
im pretty sure there is a full 9.0.1 installer if you read the release notes it mentions having to do something if you used the update but not having to do it if you just use the 9.0.1 full installer.
Old 01-15-2011, 05:46 PM
Bill Denton Bill Denton is offline
On the Avid download page both a 9.0.0 to 9.0.1 updater and a 9.0.1 full installer are available.
Just an educated guess, but I imagine the updater would not run if 9.0.0 is not installed.
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 06-25-2011, 09:41 PM
Mattct Mattct is offline
hey there,
having the exact same problem. Did the fresh install, etc.
What ended up being the solution to this problem for you?
thanks,
Matt
Old 06-29-2011, 10:27 AM
Bump. Anyone manage to chase this down?
Old 06-30-2011, 12:18 AM
Try this post: http://duc.avid.com/showpost.php?p=1810484&postcount=64
Aaron Mulqueen - 001 HD Native
Updated to Pro-Tools 10.3.6 Now Pro-Tools won't load plugins and audio suite plugins nyspaz macOS 1 07-27-2013 02:16 PM
Pro Tools Plugins Plugins Plugins psmworld Buy & Sell 0 01-31-2013 10:33 AM
pro tools le plugins B1gun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-04-2011 10:46 PM
Plugins for Pro Tools LE vs Pro Tools HD question? zilby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-31-2005 08:05 AM
Can VST Plugins be used in Pro Tools???? ian_wize 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 11-05-2004 07:48 AM
