Old 07-26-2008, 09:00 PM
bashville bashville is offline
Default Downloaded cs6, installed as cs5
I download the cs6 update, I install it. In the finder in the Digi folder, the app info says it's cs5.
Particularily hoping to try cs6, since it looks like some of the problems it fixes are the ones I'm having.
Has anybody else had this happen?
I'm running 7.4 on a Powerbook G4 running Tiger with a 4-slot Magma. I know PT is only supported up to 7.3 in this configuration, but should this make a difference as far as just seeing the correct version installed?
I'll go to 7.3 if enough people strongly encourage me to, but I'm wondering if there's just an honest mistake in the file download somehow.
Thanks for any response.
Old 07-26-2008, 09:17 PM
Drew Mazurek's Avatar
Default
Not all components are always updated with CS releases. Could be that.
www.drewmazurek.com
Old 07-26-2008, 09:26 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default
The Pro Tools application did not change, only one component:
Pro Tools HD 7.4cs6 Update
If you have installed previous updates, some file versions may not change. This update installs the following files:
  • DigiDal.kext (v7.4cs6)
  • Pro Tools HD.app (v7.4cs5)
  • DMC.framework (v7.4cs4)
  • FFmt.framework (v7.4cs4)
  • DAE.framework (v7.4cs3)
  • DHS.framework (v7.4cs3)
  • Dynamics III.dpm (v7.4cs2)
  • D-Control.bundle (v7.4cs1)
  • HWC.framework (v7.4cs1)
Administrator
Old 07-26-2008, 10:02 PM
Default
Thanks for the fast responses, guys. This helps me with the decision to move to the next possibility.
I was using a KVM box to share my biggest monitor. I'm going to take that out of the equation first, then if it's still acting up, I'll do a total reinstall with the last totally approved config.
The problem, which I didn't say before, is perfectly described in the notes for cs6. Sluggish UI, followed by crashing. Thanks again
Old 07-27-2008, 10:06 AM
studiojimi's Avatar
studiojimi studiojimi is offline
Default
2 weeks ago i tried 3 or 4 times to go to cd6 and EVER
Y TIME my 192 failed to recognize it
i have a magma chassis as well
quicktime also failed ther first time i updated waves 6.0
so i cloned back to a known good system and stayed on cs 5
and i'm not budging till i re-clone back to my reserve drive now that i have 6.0 waves running nicely on my internal primary drive
what's with cs 6?
it was a real bugger for me.
i have mentioned this in numerous threads and received no real helpful support on this.
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Downloaded Pt 8 but missed the free loops can i go back and downloaded them now? ingemar General Discussion 2 01-06-2009 07:38 AM
So, let's see what you've downloaded lately... K.B. General Discussion 3 05-17-2006 10:00 AM
Where are my downloaded VST Plug-Ins? Ditherman23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-28-2005 04:17 PM
I downloaded the demo therage Pro Tools M-Powered (Win) 3 06-21-2005 10:12 AM
downloaded 5.1, have a few q's... pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-01-2002 02:03 PM
