Old 10-06-2003, 04:37 AM
Critical Bill Critical Bill is offline
Default Can\'t record on audio drives
I have drives dedicated to audio on my Mac. A 36 gig ATA drive and a 36 gig SCSI drive. Both worked fine under PT 5.3.1. Upgraded to Mac OS 10.2.3 and PT 6.1. Now when I record to these drives, I get nothing but static and broken audio during playback. Records fine to the system drive. I did update the driver for the SCSI controller from Adaptec's website, didn't help. I did erase the drives with Disk Utility in Mac OS X and made the drives Mac OS Extended. Anyone have any suggestions?
Tim Lafferty
Mac G4 450DP, 640 megs RAM, Digi001, Adaptec 2930CU SCSI controller, Mac OS 10.2.3, PT 6.1
Old 10-06-2003, 04:44 AM
mindnoise mindnoise is offline
Default Re: Can\'t record on audio drives
Adaptec really isn´t fit for HD-Rec, they have too high a payload to the PCI Bus.
I used an Adaptec 39160 and always got System overload Errors. The Adaptec 2930 (USCSI2) worked way better, but still not flawless. I now use Atto UL3D which is approved by digi.
But this is just one option.
best
last: PT11.3.1
Old 10-06-2003, 06:36 AM
OK, but why wouldn't the ATA drive work?
Old 10-06-2003, 07:47 AM
sdemott sdemott is offline
try upgrading to 10.2.6 (or at least 10.2.4) since important CoreAudio updates were included in these...it may help.
I know 10.2.8 just was released,but I'm not going for it just yet so I won't recommend it.
Steve
Always err on the side of perfection.
External USB2.0 drives as Audio recording drives injun Pro Tools TDM Systems (Mac) 2 08-26-2006 07:06 PM
firewire drives no longer valid audio drives chuckbody1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-22-2006 11:04 PM
Still can't designate audio playback/record drives slee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-24-2005 11:36 AM
Firewire Drives vs. ATA drives for Audio Playback and Recording Chence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-26-2003 12:59 AM
Speeds for System Drives and Audio Drives Shorty B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-31-2002 08:03 PM
