Old 03-14-2003, 12:33 AM
jacko32 jacko32 is offline
Default downsides to "low latency monitor" mode
are there any downsides to this mode other than the fact that you cant use plug ins while tracking? any other pros or cons....welcome in the discussion. thanks,
Joe
Old 03-14-2003, 12:36 AM
Default Re: downsides to "low latency monitor" mode
No.. just that they're mixed in the hardware and not through the stereo buss... so they won't meter on the stereo master faders. You only want to be in that mode while recording not while mixing.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-15-2003, 03:10 PM
Mark Staples Mark Staples is offline
Do most of you bump your tracks to accomodate for the latency?
I don't "normally" track with low latency on when recording vocals because the singer usually wants a little reverb on their voice. I'll record at the 128 samples and then bump 2.7ms or thereabouts.
Mark Staples
Hearts of Fire Productions
email: [email protected]
Old 03-15-2003, 03:50 PM
It's very simple to set up an Aux send via a buss to an Aux track for reverb while in Low Latency Mode. Insert the reverb on the aux track, solo defeat the aux track and set the reverb for 100% wet.
Rail
Platinum Samples
Old 03-15-2003, 03:55 PM
powerjoe powerjoe is offline
Hey Rail,
I have tried that a thousand times as you suggested and I still get no sound while in Low Latency Monitoring mode. I've solo muted the track and everything, but for some reason, it just isn't happening. Can't figure it out.
I have to take it out of LLMM in order to get a verb or any other plugin to come through.
We keep trying though!
Joel
Joel DuBay
Ready Acoustics LLC
Bass Traps and Acoustic Panels
www.readyacoustics.com
Old 03-15-2003, 04:14 PM
Try duplicating this picture. Simply run a cable out of output 3 back into line input 4.
Rail
Platinum Samples
Old 03-15-2003, 07:01 PM
I will do it Rail!
Thanks so much for the fine illustration. That is most helpful.
You are simply amazing!
I'll let you know my results ASAP.
Now, you have been able to do this without physically running a cable line out to a line in correct?
Thanks again,
Joel
Joel DuBay
Ready Acoustics LLC
Old 03-15-2003, 10:10 PM
Bloux Bloux is offline
Rail,
Is it on my end or is that picture a little out of focus? anyone else see it fuzzy?...what a great diagram to the problem, wish i could read it better. [img]images/icons/frown.gif[/img]
Old 03-15-2003, 11:34 PM
I'll repost it without any compression... should be better. Expand it to regular size.
Rail
Platinum Samples
Old 03-16-2003, 12:27 AM
perfect bro, thank you [img]images/icons/smile.gif[/img]
How low is "Low Latency Mode" in HDN?? propower Pro Tools HDX & HD Native Systems (Win) 10 10-15-2013 06:04 PM
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
Switching subwoofer from "discrete mode" to "stereo mode"? Slerker Post - Surround - Video 6 02-11-2009 07:04 PM
Do you use the "Monitor Mode" button? Pako 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-18-2001 08:27 PM
The "dark side" of Low latency monitor petter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 08-14-2001 09:32 AM
