Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
  #21
Old 06-04-2022, 02:47 PM
Ben Jenssen's Avatar
Default Re: "Access denied" when trying to post
Originally Posted by Oliver M View Post
...believe me and don't mind me when I say that your advice is NOT the solution for everyone.
...and you can say that because?
I always prepare my posts in Apple's TextEdit (set to Plain Text) or BBEdit because I know that sometimes after trying to post a post, DUC will ask to log in again and then everything that was typed is lost
That's practical, but it's certainly not a solution to the problem.
  #22
Old 06-04-2022, 03:00 PM
Originally Posted by Ben Jenssen View Post
Again; when I get this error:
I go back
Copy the text I wanted to post
Paste it into a simple text editor, I use Stickies
Select all and copy again
Paste that into the entry field in DUC and post.
Works for me.
There's an even easier way: before you post what you write copy the material like you mentioned except when you get back to the forum thread you wanted to post to open a window to post and just paste what you copied just before. Saves having to go to a text editor. Unless you have to restart your browser the material should still be in the clipboard of whatever browser you're using.
Jack
QAPLA!
  #23
Old 06-04-2022, 03:41 PM
And that is what I do, except for very long posts with I might compose in an editor. The trap with cutting and pasting is you copy a long post to be safe, then use copy and paste to move some text around, and then the post fails... and that is a great reason on Macs to install [ADVERTISEMENT] Flycut clipboard manager https://apps.apple.com/us/app/flycut...42160987?mt=12[/ADVERTISEMENT]. Flycut makes it very easy to go back to any past cut/copy you made.
And browser back arrow will also work most of the time, but maybe not always.
I hear from Jeffro that this problem is still being worked on. I suspect NAAM might be a current distraction.
  #24
Old 06-05-2022, 12:43 PM
I have done every suggestion mentioned and had every one of them fail as often as they work. Sometimes with something as simple as 2 lines of text with nothing but basic punctuation. Then at other times, I can write a long post with multiple paragraphs with numbered points and attached photos with no problem at all. Things that make you go "Hmmm"
  #25
Old 06-05-2022, 02:47 PM
If you have a few lines of text that fail please PM me and I'll give you an email address to send to (as attachment so hopefully it does not get mangled by email).
  #26
Old 06-05-2022, 04:25 PM
Thanks
  #27
Old 06-12-2022, 10:40 AM
Oliver M Oliver M is offline
... because... I know as I tried all this, what do you think why I can say what I say?
Yes I know this smartypants, it was an example and an answer to one of the other guys responding to this thread trying to give me some advice. The suggestion to use plain txt, which I already do.
What is wrong with you?
  #28
Old 06-15-2022, 11:30 AM
jeffro's Avatar
jeffro jeffro is offline
We're finally making some progress here. I have a few chunks of text that previously triggered the error, and after some internal changes I'm able to post them.
If you have any text that causes an error when posting or sending private messages please Create A Case under Account Support to provide that text to us.
Thank you!
linkedin
  #29
Old 06-15-2022, 11:51 AM
Thanks Jeffro.
The PM message thing may help folks... you can play there sending yourself PMs without posting noise to the forum, the same mechanism and same error message will happen for a PM as it does for a forum post.
Clearly the problem is not fully fixed yet, I just sent Avid/Jeffro some more examples of failures. If you have examples of failure *please* send them in.
  #30
Old 06-17-2022, 07:11 AM
You rock, jeffro!
Thank you!
"Access denied" when saving a template ljackson Windows 2 12-23-2017 09:28 AM
Could not create a new document because Permission denied (13) while creating "test" n2one Pro Tools 12 0 05-29-2017 03:04 PM
"Could not complete your request because Access is denied" ColinSound Windows 2 05-13-2013 02:58 PM
Audiosuite "Access denied" trey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-07-2002 08:20 PM
"access denied" when using audio suite plugs lewis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 25 08-16-2001 12:52 AM
