Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-20-2021, 01:07 PM
Juicecastle Juicecastle is offline
Default Waveshell pause on start up (loading plugins)
Hell everyone
Not sure if this is the right spot for this question. For those that have waves plugins do you get the waveshell (loading plugins) pause on startup? is this something normal? i've updated to the latest version of waves uninstalled and reinstalled and still pauses on waveshells???
Old 01-20-2021, 03:44 PM
jeff markham's Avatar
jeff markham jeff markham is offline
Default Re: Waveshell pause on start up (loading plugins)
It's normal. The Wave Shell iterates through and enumerates out all the Waves plugins that you have. The first time is pretty slow after that, it's faster .. but it does take a while. That's one of the bummers about shells ... they don't cache as well as the other AAX plugins.
Old 01-23-2021, 01:54 PM
glenwoodedit glenwoodedit is offline
Sometimes the Waveshell will hold up on Pro Tools launch for a longer than usual time even after a first time launch. This may be it trying to phone home or authenticate to the licensing device.
One way to speed it up is to trash the license folder on the Waves Flash drive or Hard drive where you have your Waves License (Waves>License) this is for Mac OSX. Then go to Waves Central and let it rebuild the license file when you login.
Waves Central is not a big fan of sitting behind proxy servers or other limited Internet connections. We experienced this issue on Pro Tools on Mac OSX sitting on a network connection that used a proxy.
Old 01-25-2021, 08:33 AM
seanmccoy seanmccoy is offline
I suspect this it true. I've found that if I keep my workstation offline for an extended period, the Waveshell scan takes longer and longer. After going online and starting Pro Tools, it then speeds back up. I also always log into Waves Central while online once, just to be safe.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 01-25-2021, 09:17 AM
JFreak's Avatar
JFreak JFreak is offline
It is spelled WavesHell
Janne
Old 01-25-2021, 03:16 PM
EGS's Avatar
EGS EGS is offline
It's slow only when I'm in a hurry...
Click for audio/video demo
Click for resume
Old 02-28-2021, 02:40 PM
psycho's Avatar
psycho psycho is offline
I've had the same problem. It's a Waves bug that already has been fixed. See here: https://www.waves.com/downloads/release-notes#v10
From their release notes:
June 18th, 2019
... Fixed: Bug which caused long plugin scan and loading times on computers not connected to the internet ...
PT Ultimate 2022.12, HD-Native PCIe, 4x 192 I/O, Sync HD, MIDI IO, 2x Pre, 40 Channel Icon D-Command, X-Mon
PC: Windows 10 Pro, Intel i7-10700KF, 32 GB DDR4 3200 RAM, MSI MEG Z490 Ace, Nvidia GTX 950
Notebook: Windows 11 Pro, i7-1165G7, 16 GB RAM, 2 TB SSD
Old 02-28-2021, 02:50 PM
June 18th, 2019
Interesting. It's well into 2021, and I'm still seeing this behavior. Maybe there was a different, more consistent bug that slowed down the scan that they fixed, but whatever causes this cumulative offline issue hasn't gone away.
Old 03-14-2024, 01:55 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Has there ever been a fix for this issue other than deleting the waves local server ? Out of nowhere I have the super slow loading waveshells on PT startup (10-15 minutes). Also instanciating waves plugins onto tracks is super slow.
Thanks in advance for helping.
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Pro Tools 9 "Quits Unexpectedly" on start, when loading Plugins! dbC4G macOS 6 04-06-2012 05:51 AM
waveshell DAE 5.0.5 makes PT vanish during loading screen?? test tube AUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-27-2008 12:08 PM
Long Pause while loading, searching for wave files bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-16-2004 09:00 AM
Freezing on Start up while 'loading plugins' soundminded Pro Tools TDM Systems (Mac) 2 10-14-2002 08:59 AM
Crash when loading Waveshell with iMate Thierry Peters Pro Tools TDM Systems (Mac) 0 07-31-2000 03:47 AM
