Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 10-23-2020, 01:01 PM
summit01 summit01 is offline
Default Speeding up and slowing down PB in ProTools
Hey guys,
I would like to speed up or slow down the playback in pro tools in HT-steps. Like in the old days with the studer 2"... play it back at lower speed and record, then play it back at normal speed. (similar to shift-space function/ -12HT)
I definitely dont want to time compress it with elastic audio or TCE nor melodyne it.
Since Im working with Apogee bigben as a clocking unit, it will allow me to speed up or slow down the clock by 1% or 4%. So basically to run the whole system at 50kHz. Im getting the desired change in tempo and pitch and hearing no artifacts? Im wondering if any of you have better ideas to approach the matter?
Thanks D
*MacPro Rack 16 core| 96GB Ram | OSX 10.15.4
HDX l 5x 192 I/O | PT Ultimate 2020
*MacPro Quad 2.66 | 6GB Ram | OSX 10.9.8
HD6 Accel | Magma PE6R | 2x 192 I/O | PT 10
Old 10-23-2020, 06:24 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Speeding up and slowing down PB in ProTools
While it's listed under Elastic Audio, the Varispeed function is what I use for recording at a different speed. Basically you enable Varispeed on all the tracks in the session including the one you're recording with, then change the tempo to play everything faster or slower while recording the new audio. Then when you're done, change the tempo back to the original. You can then just disable Varispeed on the original tracks, and commit the Varispeed on the new track(s) - don't use X-form on it though because it will then stretch or compress the audio - just commit it as is and it should be synched with the session at the correct tempo.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-08-2024, 04:48 PM
Mr.Golden Mr.Golden is offline
summit01 !!!!
Thank you so much! I have been wondering about this for years and did not know about this. I learned on cassette 4-tracks and Reel-to-Reel machines in the 90s and have been trying to figure out a better way to do this than pitch shifting (without time correcting) all the tracks to the desired speed/pitch, recording, and then pitch shifting everything back.
You just saved me a whole lot of time!
Cheers!
midi tracks (including click alone) speeding up/slowing down? awritersparadise Pro Tools 11 0 12-16-2014 06:34 PM
Speeding Up/Slowing Down Audio Tracks? TigerTwin macOS 2 08-19-2011 06:38 AM
speeding up protools? CrAkD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-06-2008 12:55 PM
Slowing down or speeding up songs in PT Michael Carpenter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-27-2002 10:18 AM
Speeding up/slowing down, guide click for band while in record? Jules Tips & Tricks 2 01-04-2000 06:21 PM
