Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 09-24-2020, 12:42 AM
noiseboyuk noiseboyuk is offline
Default Known plugin conflicts
Plugin conflicts can take weeks or months to track down, a useful repository of these would be helpful. I'll try and keep the list in the OP up to date.
iZotope RX Connect (any version) and Native Instruments Kontakt (any version)
Causes crash when loading most nkis in Kontakt. Only workround for now is to close RX Connect from AudioSuite before loading a new instrument in Kontakt. NI are aware of the issue.
(Reported in all versions of PT up to 2020.9.1)
iZotope RX 7/8 (in AudioSuite) and Sonnox Oxford Drum Gate (higher than 1.0) and other Oxford plugins
Fixed in latest build of Oxford Drum Gate, being worked on for other Oxford plugins.
Any iZotope RX7 plugin and GRM Tools
Causes crash if GRM Tools is inserted anywhere in the session and RX is in Audio Suite
Opening any RX plugin causes crash. Both companies aware of the issue.
(Reported in all versions of PT)
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 09-24-2020, 01:31 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Known plugin conflicts
Made this sticky. Now just everyone please post your findings... also bear in mind what you post does not need to be reproducible on other systems (sometimes it is not) but anything that you think others would find good to know.
Janne
Old 09-24-2020, 10:20 AM
Thanks v much Janne.
Just updated to 2020.9.1 today, no change to the RX Connect / Kontakt crash.
Guy Rowland
Old 09-24-2020, 09:37 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Switching an Insert from an Instance of Komplete Kontrol to one of Kontakt.
Locks up every time. I haven’t filed any bug reports. I probably should. I just purged KK from my template, but I had to open some sessions from those dark years recently, and I forgot about that bug, much to my suffering.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 09-24-2020, 10:31 PM
Roll Roll is offline
Opening a rx7 audio suite plug-in, when a GRM tools is in insert on the session ...
Old 09-25-2020, 01:24 AM
I just tested this here and it worked ok in 2020.9.1, latest versions of KK and Kontakt in Win10. Can I just check I'm following the right steps? This is what I did
1. Insert Komplete Kontrol on an instrument track, load a patch
2. Replace KK with Kontakt, load a patch.
Guy Rowland
Old 09-25-2020, 01:28 AM
Thanks Roll - Mac / Windows? Any particular version(s)?
Guy Rowland
Old 09-30-2020, 09:38 AM
StudioRhythm StudioRhythm is offline
Thanks for starting this thread, Guy!
I heard back from Sonnox Support yesterday and can confirm that there's a new version of Oxford Drum Gate (v.1.05) that solves the iZotope RX7 AudioSuite crash problem.
In the process I did discover that the current versions of Oxford Dynamic EQ, Inflator and VoxDoubler all suffer from the same bug though. Sonnox says they'll all be fixed soon, within weeks.
www.studiorhythm.com
Old 10-01-2020, 12:32 AM
Good news, have updated - thanks!
Guy Rowland
Old 10-01-2020, 07:19 AM
daeron80 daeron80 is offline
Curiously, there's not a conflict between Sonnox SuprEsser and RX. Been using those together on both Mac and Windows for years.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
HD TDM / Quicktime conflicts... Codo Pro Tools TDM Systems (Mac) 5 06-24-2012 07:29 AM
CPU Conflicts Siegfried Meier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-08-2007 10:48 PM
PT and Rhapsody Conflicts TMitchJobe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-03-2006 06:13 PM
Plug-in conflicts grobb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-24-2003 09:48 PM
Known Extension conflicts! Dan L General Discussion 8 06-10-2001 12:18 AM
