Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 07-22-2020, 01:42 PM
Finnmaker Finnmaker is offline
Default Import session data main playlist imports unwanted clips
Hey, I'm wondering if someone knows if everything is working as intended here, am I missing something or is this a bug:
I want to import only the main playlist of a track to a new template we have for mixing. Also I'd only want to have the clips imported that are on the main playlist. So none that are in the alternate playlists since there are a few hundred of these... But regardless of me unticking the alternate playlist option PT brings all of the clips from the previous session, only with the difference that there are now no playlists but the clips are still moved to the new location. Is this intended?
I'm on PT 2020.3 Ultimate.
The clearest workaround is me exporting all of the audio files separately and then match the track data, but we have about a 100 tracks and 11 songs... This'll take ages.
2nd option is importing the files like this, then choosing all unused files and deleting them, but risking the bug that some pro tools has had that it doesn't recognize the imported clip folders correctly and accidentally deletes the original files. (We've had this bug pop up twice on previous sessions, so wouldn't want to risk it)
Or 3rdly save copy in from the previous session and import the other way round. The issue here is that we have the template session set up with our S1 consoles and you can't import those with session data. (This way only the main playlist clips are imported as intended)
Last option is to do the third option and after that import the session data from that copied session.
Everything seems so fiddly compared thing that should work on it's own just with a single option when importing: "Only import clips on main playlists"
Old 07-23-2020, 02:56 PM
ZEUSS ZEUSS is offline
Default Re: Import session data main playlist imports unwanted clips
This has happened to me. The regions bin was filled with files from the session importing data from even through I only wanted the files from the top playlist imported...
This was also a bug in the past as well. It has been fixed a few times....
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 07-24-2020, 01:40 PM
Updated to 2020.5. Still insists. The "Save Copy In" option works as a workaround and brings only clips from the main playlist. I'm going with that for now and then importing the copied session data into my template and deleting the copies manually.
Would still think this is a bug or at least an unwanted feature.
If anyone cares to try and replicate:
1.Create a track and record on multiple playlists, using duplicate playlist to create the new tracks. (not sure if the playlist duplicating is necessary to replicate the behavior)
2. Comp a track and consolidate so that only 1 clip is on top.
3. Open new session
4. Import session data from session #1, untick alternate playlists
5. watch how many clips PT imports.
Old 02-07-2024, 07:50 AM
Ryan Kelly Ryan Kelly is offline
Ran into this with 2023.12.1 as well. It seems that manually selecting and de-selecting Alternate Playlists in the Import Session Data window is then only bringing in the main playlist but will see if that keeps working
Import Session Data - no clips bitconductor Pro Tools 2019 3 10-30-2019 12:57 PM
Import session data in one Playlist Tank Pro Tools 10 4 03-10-2018 02:27 PM
Import Session Data - No Waveform in clips mgoorevich Post - Surround - Video 3 10-15-2014 10:40 PM
import session data creating unwanted trim automation zakco Pro Tools 10 1 11-27-2013 02:51 PM
Import Session Data takes in unwanted audio Arno Peeters Pro Tools 9 8 02-09-2011 06:25 AM
