Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-01-2020, 06:03 AM
Mark Norup Mark Norup is offline
Default Media Offline
When importing a DNxHD film in to PT 2020.3 it says media offline ? All has been working perfect I 2019 - my system is OS Mojave 10.14.6
Kind regards
mix engineer
Mark Norup
www.marknorup.dk
Old 04-01-2020, 08:07 AM
Reckless Erik Reckless Erik is offline
Default Re: Media Offline
Move the video to a separate drive. It seems to work. God knows why they have changed this.
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 04-01-2020, 08:29 AM
emj_antonin emj_antonin is offline
I had the same... I also needed to re-render the video from DaVinci Resolve Studio, using another codec (ProRes 422HQ instead H.264). No way to have the video played from the usual/original Video Files folder inside the Session Folder.
Old 04-01-2020, 08:32 AM
oudi oudi is offline
hello
same here
i've changed the name of the video and everything work again.
best
jf
Old 04-01-2020, 09:10 AM
Working fine here...
MacBook Pro 2019
10.14.6
PTU 2020.3
HD Native + Omni
DNxHD36 video file in .mov container is in Video Files folder, inside the session folder, but the whole session folder in on a Samsung T5 external drive.
EDIT: To be fair, this was opening an existing session after updating from 2019.10 to 2020.3. I'll check importing a video into a new session to be sure.
EDIT2: Created a new session on the internal drive. Copied video file into Video Files folder of that session. Then imported video into session. Still working fine.
Scott Gatteño
Old 04-01-2020, 11:51 AM
andystar andystar is offline
in my case problem was in non-English characters in video folder name. Try to copy your video directly to desktop and import
Old 04-03-2020, 01:30 AM
Thats was the problem :) Im from Denmark and we got aøå when I removed that the DNxHD files all played back as they should. Thanks everybody for helping.
Now the import of OMF files error needs to be fixed, is there any of you that have had problems with OMF import? AAF works perfect.
Kind regards
mix engineer
Mark Norup
www.marknorup.dk
Old 04-06-2020, 04:48 AM
audiojavi audiojavi is offline
In Spain same problem. Non-english characters. Solved removing "Ñ" character from filename. Now working fine
Old 04-06-2020, 05:29 AM
JFreak's Avatar
JFreak JFreak is online now
Always safe to assume you can only use ASCII 7bit characters for file names, and even then avoid special characters to be safe...
Janne
Old 05-09-2020, 09:42 AM
ianob ianob is offline
Just upgraded from PT12.6.1 to latest PT2020. First project I (re)open gives me the MEDIA OFFLINE error.
Sure enough, changed the video name to ASCII (English) characters and the video works now.
Only problem is EVERY SINGLE VIDEO I HAVE BEEN WORKING ON SINCE 2015 has Japanese characters. So I can't load any of my old sessions without changing the video filename.
Does anyone know WTF is up with this? Workaround? Can I keep an older version of PT that doesn't have this issue and run it alongside the latest one?
Or does anyone know at which version the video engine stopped supporting non ASCII characters??
I am not amused.
MEDIA OFFLINE on PT2020.3 belasoul Post - Surround - Video 9 05-10-2020 11:47 AM
Media Offline? CygnusX-1Bk2 Pro Tools 12 3 04-26-2020 08:49 AM
How to log offline media?! Frank Kruse Post - Surround - Video 5 08-19-2005 02:19 PM
Logging Offline Media Rizman Pro Tools TDM Systems (Mac) 1 04-01-2004 11:56 AM
OFFLINE media/audio ongaku 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2004 01:54 AM
