Old 02-18-2020, 12:31 AM
Kayonardo Kayonardo is offline
Default Permanently sync projects on 2 computers
Hello!
I plan to use Pro Tools on 2 computers and would like to have access to all my projects all the time without thinking of backups and transfers all the time.
But I do no yet plan to collaborate with other Pro Tools users.
I Avid Cloud the way to go anyway?
Thank you!
Old 02-18-2020, 04:47 AM
peterle peterle is offline
Default Re: Permanently sync projects on 2 computers
avid cloud seems not optimal , regarding transferrates etc,
btw you need always internet connection and its limited,
better solution could be a small network with a NAS
for example and attached volumes (HDD or SMM) which
you could use as a central storage and/or backup solution.
foley artist , soundeditor
Old 02-18-2020, 08:25 AM
FunkzzaJ FunkzzaJ is offline
Used Google drive. Poor performance. Too bad sometimes. That led to a mess of almost-duplicates with different content in the PT .bak files.
Now after tidying up, I use a simple 64 GB USB memory stick. Not as a recording drive but storage and transfer.
No proper backup regimen for it yet.
Works fine so far. Maybe you need more GB.
/Fzz
Skickat från min Moto G (5) via Tapatalk
Free beer tomorrow !!
- but until then -
we're stuck in the present moment
Old 02-19-2020, 02:54 AM
climber climber is offline
yes... A Network Attached Server is likely the best solution. I've used that here for some time. 100BaseT is pretty fast.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 02-19-2020, 07:28 AM
Lynn Gräber Lynn Gräber is offline
I work directly out of a Dropbox local folder on a dedicated drive. My assistants also have access to this folder for prepping and delivery from their own studios. Everything syncs quietly to and from our computers, to the cloud and to my backup server over in the corner.
Old 02-19-2020, 08:45 AM
TrentWilliams TrentWilliams is offline
Backblaze, or setup a consistent backup using Carbon Copy Cloner would be my suggestion.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 02-19-2020, 01:38 PM
daeron80 daeron80 is offline
If the computers are at the same location, a network server with all devices attached at 10 GB or better.
If the computers are not normally at the same location, and you have fast internet access at both locations, Dropbox works. It has served me well for that purpose. Just work directly in a Dropbox folder. If you don't have fast internet at one or both locations, a large USB flash or SSD drive is just about your only decent option.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 02-19-2020, 11:22 PM
Many thanks for all your suggestions!
Old 02-21-2020, 10:42 AM
made made is offline
I can recommend Resilio Sync. In combination with a NAS (it runs on Synology) no need for any Cloud service. Your hard drive is your storage limit.
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78)
LIO-8
BlackmagicDesign UltraMonitor3G
Reaper 6.66, Fireface UCX
MacbookPro M1Pro PTHD2021.12 MacOS12.1
MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB
Old 02-25-2020, 11:24 AM
Ale Ale is offline
We use chronosync from econtechnoligies to sync to other computers or external devices. It runs in background and you can also sync to cloud services or incombination with chronoagent to a remote Mac via internet
Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Getting Sync to default new projects to a specific setting Dizzi45Z Pro Tools TDM Systems (Mac) 1 10-20-2014 11:00 AM
How do I sync two pro tools computers together? iAmLegion3614 macOS 4 12-29-2011 06:22 PM
Sync two computers Hamdi General Discussion 0 05-19-2011 12:02 AM
Can not sync two PT 9 computers..Help dcdiscs Pro Tools 9 7 04-21-2011 11:19 AM
Sync two computers with one interface(Digi002) fortycentface 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 06-21-2008 09:48 AM
