Old 01-15-2020, 07:52 PM
Chase Orion Chase Orion is offline
Default Scrubbing causes PT crash
Everytime I use the scrub function Pro Tools 2019.12 crashes. I am using Mojave 10.14.4.
Does anyone know how to fix this?
Old 01-15-2020, 09:18 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Scrubbing causes PT crash
Hi, Not without tons more info - start here: Help Us Help You
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-20-2020, 11:10 PM
Here's my setup info.
Lynx Hilo via thunderbolt
2018 15" MacBookPro
Mojave 10.14.4
2.9 GHz Intel Core i9
32 GB 2400 MHz DDR4
Radeon Pro Vega 20 4 GB
Intel UHD Graphics 630 1536 MB
Pro Tools 2019.12
This problem happened in Pro Tools 2019.6 as well. Everytime I scrub it for a few seconds it crashes my session.
Old 01-21-2020, 12:55 AM
peterle peterle is offline
as usual: trashing preferences
check if graphics and audio driver are up to date
foley artist , soundeditor
Old 01-23-2020, 07:34 PM
Trashed the prefs and its still doing the same thing. All the drivers are up to date.
Old 01-27-2020, 05:12 PM
Any other solution for this problem? Or has anyone else experienced this?
Old 01-27-2020, 06:05 PM
What exact “crash” is happening... exact error messages if any, what exactly do you see happen?
When did this start happening? What changed? Does it happen for all sessions? Only one? A few?? IO buffer size? Session sample rate?
Lots more standard troubleshooting to try...
Set the IO buffer to the max size, uncheck ignore errors... what happens?
Test with other sessions and/or starting with a totally empty session
Removing all .aaxplugin files And trashing prefs again... can you reproduce with the standard minimal Plugins that get automatically reinstalled?
Creating a new admin account and repeating tests from there.
Test using BuiltIn Output as the playback engine?
Crash crash crash crash crashhhhh crahshrbnjfgeviufdbldfgvjndgokhng FuneralMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 27 11-16-2009 12:02 AM
Crash Crash Crash Live 6 Pro Tools Rewire TimmyP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-12-2007 11:26 AM
SCRUBBING=PT CRASH ewoklake Post - Surround - Video 0 01-29-2006 11:05 AM
SCRUBBING=PT CRASH ewoklake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-29-2006 10:58 AM
Installed 32track le version, won't run with Reaktor crash crash crash Christian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2002 11:05 AM
