Old 06-18-2019, 10:22 AM
monet monet is offline
Default 9173 error still/trash can, 35%cpu or less?
deal! anyone still having this "fixed" issue?
mac trashcan 8 core
64G RAM
OS mojave
PT 2019.5
Audient ID 22
Old 06-24-2019, 10:05 AM
Jazzbass56 Jazzbass56 is offline
Default Re: 9173 error still/trash can, 35%cpu or less?
I feel your pain.. I wish the industry would move away from PT it has become a unstable dinosaur
Intel Intel Core i7-5930K 3.5 GHz Processor
ASUS X99-PRO/USB 3.1 Motherboard,64 GB crucial DDR4 ram
Thunderbolt EX 2
Windows 10 Pro
2013 MacBook Pro Retina i7 Quad-core, 16gb ram.
Mac OSX 10.11.6
Mac Pro (Late 2013)
2.7 GHz 12-Core Intel Xeon E5
Memory 128 GB 1866 MHZ DDR3
Graphics AMD FirePro D700 6144 MB
PT Ultimate 2022.4.0 on Mac
PT Ultimate 2020.12 on Windows
Logic Pro X 10.6
Nuendo 12.0
1_Antelope Audio_Orion Synergy Core Studio
Old 06-24-2019, 10:29 AM
JFreak's Avatar
JFreak JFreak is offline
Not much info here. Please spend some ink so that someone may be able to help you
Janne
Old 06-24-2019, 03:57 PM
innesireinar innesireinar is offline
I'm experiencing the 9173 some minutes after opening and running a session. But it happens only one time. I'm doing an intensive test for discovering which plugin would cause this, if any. After many test I discovered that Kontakt in the plugin folder (even if not running) is the most responsible. But I have to investigate further. Btw the 9173 doesn't show up with only avid plugins in the plugin folder. I ran many sessions for many minutes going back and forth between one session to another, by closing pt, restarting the mac, reloading the missing plugins (after removing third party plugins from the folder) with avid plugins for loading the cpu and the hdx chips and never seen the 9173
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 06-24-2019, 04:09 PM
xrekcor's Avatar
xrekcor xrekcor is offline
I get the same error and usually only once.... and usually with the first session play through. I have found for me it’s due to forgetting to turn the internet connection off. If I turn it off prior to launching PT I don’t get the error.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 06-24-2019, 04:16 PM
tclash tclash is offline
Thank you for doing all this testing. I have the same 9173 situation as you (happens just once usually in the first 10 minutes of opening), although sometimes it's 6101 instead of 9173. I also have Kontakt and will try taking it out of the plugin folder.
Old 06-24-2019, 04:37 PM
Are you referring to wifi or internet in general?
Old 06-24-2019, 05:39 PM
xrekcor's Avatar
Internet...... I run WiFi on a private network isolated from the internet to run EuControl without any issues. I believe there is a conflict happening between PT in play/record mode (I mean physically playing and recording) and the background chatter your PC does with your internet provider.
Rob
Old 06-25-2019, 01:14 AM
clancychris clancychris is offline
What interface are you using?
For years I've been using an Apogee Symphony through a PCIe card. Never get errors.
I bought an Apollo firewire quad and after 30% CPU usage sessions were barely workable.
I know firewire is outdated but just putting it out there that it was an interface issue with me
Old 06-25-2019, 05:13 AM
I will check this too
AAE error -9173 with Pro Tools 2018.12 on macOS 10.14 Mojave ramonetl Pro Tools 2018 17 04-19-2019 08:44 AM
VCA Function That Raises Some And Lowers Others? NateAlexander Tips & Tricks 11 02-06-2019 05:05 PM
1st Mojave error mspin macOS 14 11-21-2018 05:15 AM
Avid to drop prices on products!? M-ManLA General Discussion 17 08-31-2011 11:19 AM
