Old 04-09-2018, 08:18 AM
sdmaas sdmaas is offline
Default ADC outta whack
Yesterday my sessions worked fine, ADC was no issue. Today, I imported a session from PT9 (not HD) into an HD session and the ADC was so messed up after the import, it sounded as if the delays were way off. Now, if I put any plug-in on an Aux, it immediately throws a ton of delay on it. For example: UAD 1176LN puts 6276 samples of delay on AUX tracks while only 2112 samples on Audio tracks (usually the same?); Waves CLA-76 puts 4164 samples of delay on AUX and ZERO on Audio tracks...
For some reason, I am getting this extra 4164 samples of delay on AUX tracks that did not exist before.
Every session of mine now has the ADC all screwed up; I cant even stand to listen to the sh** anymore. WTF happened?
Old 04-09-2018, 09:21 AM
Default Re: ADC outta whack
So I ended up turning off ADC in the Playback Engine and turned it back on, and it worked like normal again...
Is this something that has to be done any time I import a non-HD session in HD?
Old 04-09-2018, 09:45 AM
Maybe(and good detective work) another thing that can throw a wrench in ADC is if you have a send that goes nowhere(example, you send a track to an AUX with a reverb plugin, then change your mind and delete the AUX track).
click/count-off out of whack Riverblack Pro Tools 12 3 05-25-2015 07:19 PM
Pro Tools Sync Out Of Whack phoketztight Pro Tools M-Powered (Win) 10 12-29-2007 07:34 AM
Fader 3 Out of Whack. blairl ICON & C|24 1 03-27-2007 02:01 AM
Midi out of whack! Imagine Pro Tools TDM Systems (Mac) 3 07-24-2004 12:26 PM
Specs Whack? thejewdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-13-2004 09:41 PM
