Old 03-27-2014, 09:26 AM
Default GUI not working on channel strip?
I have an AVID channel strip (multi-channel) on LCR to LCR AUX bus. I can hear the compressor doing it's thing like crazy but I am seeing no activity what so ever in the compressor GUI. I see the I/O meters but the little red dot just sits there as if the track was muted.
Also the gain-reduction meters in the mixer shows zero activity even though -3dBFs are going in and -20dBFs are coming out of the plugin.
This is with just something in the Center channel. As soon as there's something in the L/R it works fine.
Is this a feature or a bug?
Thanks,
Frank.
Old 03-27-2014, 10:33 AM
Default Re: GUI not working on channel strip?
Ok, so I switched it to multi-mono and now I can at least switch the GUI to center. Would be better if that worked in multi-channel mode as well.
Seems like it only works for L/R there.
Frank.
Old 10-19-2014, 02:53 AM
Schottlandru Schottlandru is offline
Grüß Dich Frank,
Half a year on, is there any news on this? I really miss being able to view the center gain reduction response. Multi-mono as far as I understand doesn't allow for different key source methods, so one cannot have for example a loud shout on C reduce the center AND the reverb in L/R and even Ls/Rs on the dia bus for example.
Multi-mono would change the reverb ratio unfortunately.
Hope this GUI issue will soon be or by now even has been addressed?
Andrew
Old 03-10-2015, 07:16 AM
kaioflex kaioflex is offline
just experiencing the same problem. any news on this?
Old 03-10-2015, 07:22 AM
interesting: when I activate the exp/gate, the red little dot starts to work... even for comp/limit. working only with comp/limit has no red dot
Old 03-10-2015, 07:41 AM
OK here it is: the depth knob on exp/gate activates the red little dot working and jumping. great bug!
Old 03-10-2015, 08:41 AM
reichman's Avatar
reichman reichman is offline
I've seen this bug before, too. Can't remember what I did, but the sound passing through CS was fine.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-10-2015, 09:17 AM
correct. technically it is working fine. but sometimes you want to see what you are tweaking on
Old 07-07-2015, 06:15 AM
Avid,
any news on fixing this issue? It's very irritating to work with a multi-channel plugin that doesn't have visual feedback on what it's actually doing. The issues seems very inconsistent too. The other day I saw it only showing gain-reduction or any activity when there was audio in the rear surround AND the front. No activity when routed to L or R. One restart later, no GUI at all but audible compression. On the next restart, the usual activity only when routed to L or R.
Thanks,
Frank.
Old 07-07-2015, 06:50 AM
quadraphonics quadraphonics is offline
I showed this very thing to people from AVID almost a year ago.
Randall
Originally Posted by Frank Kruse View Post
Thanks,
Frank.
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
HTML code is On
ALL-LINKED feature on channel strip not working? lululu Post - Surround - Video 4 09-28-2013 09:05 AM
Channel Strip on 11r derker Eleven Rack 8 04-28-2013 05:37 PM
Renaissance channel vs Channel Strip frenchman Tips & Tricks 1 09-20-2003 05:18 AM
Who's using MH Channel Strip?? crowdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-04-2001 11:35 AM
Channel Strip & 5.1 nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-03-2001 08:22 AM
