Pro Tools 11 software help needed!
hi!
I recently purchased pro tools 11 and since getting it I don't have the Digidesign folder or am able to install or use any plugins that come with the program, Ive uninstalled and reinstalled pro tools to no avail and am at breaking point trying to figure out a solution! Anyones help / advice at this time would be awesome I'm running on a Mac OS X LION version 10.7.5 A 2.5 Ghz intel core with 4GB 1333 MHz DDR3 Start up disk Mac HD and i have a Fast track audio interface any help would be muchly appreciated! Daniel Zinetti |
Re: Pro Tools 11 software help needed!
I think u need OSX Mountain Lion....at least that is what the system requirements state.
You're going to have to upgrade OSX to Mountain Lion; at least OSX 10.8.3 but preferably the latest of OSX 10.8.5 More ram - 4 gig is barely enough to get things working. A second hard drive for PT to record to. Second drive must not be a green drive and never set to sleep. For that matter your whole system must not be allowed to sleep as that can and will cause problems with PT. You don't say what exact Mac you have so port connection depends on that. Thunderbolt if you have such a port; next would be either FW800 or USB3 (USB 2 isn't fast enough). Properly optimize your computer. That means turning off the aforementioned sleep modes for drives and system. Turning off Spotlight indexing. Turning off wireless networking. A Google search or a search will turn up other things to be done. Plugins are a separate download from the main program. |
Pro Tools 11 is different than previous versions. No more digidesign folder (or avid folder for that matter), just the application package in your applications folder. As mentioned above you have to download and install the instruments separately.
I've read on this forum that a few people run ProTools 11 on 10.7.5 with no issues, I have a sound editor friend who is running it on Lion as well and so far so good...But I was already on Mavericks when I installed it so I can't really comment. And yes you definitely need more ram...
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4 Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control NI Komplete Ultimate 11 Albion One Soundiron Choirs Pianoteq Analog Lab VSL SE/Chamber Strings etc |
Not quite right. Although the PT program no longer resides in a subfolder but directly in your Applications folder there are still Digidesign (if you have PT10) and Avid folders (for PT11) that contain the plugins.
Yes but these folders are just aliases. The actual plugin folder is in /Library/Application Support/Avid/Audio/Plug-Ins. ProTools 11 doesn't use the avid folder where PT10 resides (I think even PT10 used the renamed "avid" folder btw). On one of my Mac Pros I have only PT11 and there's no avid folder at all. I have it on my other Mac only because PT10 was previously installed (and still is since the uninstaller doesn't seem to work with Mavericks, so I leave it there until I can get rid of it)
I doubt that, especially for large sessions or using lots of sampler vi's. Too slow.
Pro Tools "M-Powered" Essential Software needed | Neil316 | Pro Tools SE and Essential (Win) | 0 | 10-07-2012 06:22 PM |
Software needed | Scotty_in_oz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-27-2009 04:06 AM |
Volunteer Pro Tools LE Software Wizard Needed | JKirsch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-16-2006 09:49 AM |
Software Update Help Needed | PTGuy | Pro Tools TDM Systems (Mac) | 6 | 08-19-2005 07:50 PM |
Software sampler needed. | MikeC | General Discussion | 0 | 11-27-2000 02:30 AM |
