Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 03-26-2011, 09:33 AM
Default 16GB working?
I am trying to transfer a QT that is a bit over 16GB in size.
AFAIK, the 16GB/file restriction was overcome with one of the later server software updates. However the PDF of the official client still states that a single file can not be larger than 16GB.
My question is: What is the current status? IS there a 16GB limitation for a single file or is there no limitation?
Background is that I am trying to upload this QT and it never finishes. Tried 3 different Macs (both intel and PPC with Leopard or Tiger) and both the latest official client and the latest beta of the client.
Has someone ever successfully uploaded a file that was larger than 16GB? Can someone confirm that more than 16GB for a single file actually work?
Thanks,
Frank.
Old 03-27-2011, 03:04 AM
Default Re: 16GB working?
Update:
I split the QT in two halfs and they uploaded just fine. So I guess the 16GB restriction still applies unlike stated in the sever software release-notes.
Hope this info helps others.
Critically low with 16GB? WestexasSD macOS 15 12-28-2013 06:57 AM
CPU Overload w/ MBP i7 2.4Ghz & 16GB Ram dolla45 macOS 13 09-04-2013 12:30 PM
iMac 21.5 with 16gb, JustGotPaid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-12-2013 07:59 AM
critically low on memory...? WTF? We have 16GB. KingTor macOS 8 11-09-2012 09:09 PM
When will the 16GB limitation be dropped? Frank Kruse Aspera DigiDelivery 0 07-25-2007 05:02 AM
