Power Consumption
Anyone know how much power an HD2 Accel system needs?
Here's my problem: I have a Tyan Tempest i5400XL mobo, 2 x 2.5GHz Quad Core processors. It has 8 memory slots, I currently have 4 slots filled with 2Gb memory modules. If I fill the other slots then the PC won't boot at all, except if I mess about with the memory channel parameters in the BIOS ( before installing the memory) and change it from interleaved to Sequential, in which case it boots but only POSTs 4Gb of memory. Tyan suggested that I may not have enough power. The company that built the PC say it's a 700W power supply and that should be enough, but my guess is that they may not have built too many HD systems. Grateful for any ideas. 8Gb memory is fine, but having spent the money I'd like to able to use the full 16Gb that I bought. Lennie |
Re: Power Consumption
Windows is only going to see 4GB.....Just guessing your are going to need need 4 1GB stcks of RAM to actually get your board working with a pair of sticks for each processor so it will run in dual channel mode.
Quick way to possibly tell if its the PSU would be to see if it will boot with 8GB and no cards in it.....
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
I'm using Windows 7 64-bit. Regardless, the PC should see all the memory when it boots. I've swapped the modules around to check for a dodgy one, computer boots with any 4 of them....
I had a similar problem with switching from 4 gb to 8 gb in Windows 7 64 bit.My problem was a Asus p5kc mobo.I installed 1066mhz ddr2 memory but mobo (p35 chip) supports only 800mhz,but the manual says it supports 1066 natively..I had to give up a higer frequency and windows started to boot up with all 8gb of memory ..or do more changes in overclocking area of mobo(memory voltage,CPU voltage NB frequency..).It also worked when I changed memory settings from 5-5-5-15 which is default on memory sticks, to 5-6-6-18 and than windows also would boot up...but due to overheating components of mobo which resulted in system instability, finaly I gave up and sticked to 800mhz and whole system works nice .Hope this helps some way..
Musician,Producer etc.. PT|HD Ultimate Native , UAD-2 Octo x2 , Win 10 Pro 64 bit, AMD ThreadRipper 3960X (24 cores 3,7Ghz (48 threads), 64 GB G.Tech DDR4 3200MHZ ,Gigabyte TRX40 Designare (with Thunderbolt), (Philips 40'LED screan) , Samsung 24" LED 2x192 I/O, Nuendo 4.3, Wavelab 6, Halion 3.5, Yamaha 02R96V2, AvalonAD2022, AvalonVt737sp etc... www.MrPollack.pl ,www.facebook.com/polak.bros.studio |
Mbox 2 power consumption? How much of a power load is this | spaids | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-30-2007 06:27 AM |
Power Consumption | dloeliger | VENUE Live Sound Systems | 1 | 03-06-2007 09:13 AM |
power consumption 002R | Shindog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-25-2006 07:39 PM |
Power consumption of Mac / UPS | imp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-30-2001 03:23 PM |
Mix Cards Power Consumption | stevegalante | General Discussion | 0 | 02-15-2001 07:13 AM |
