Old 10-04-2009, 03:16 PM
redchair redchair is offline
Default PT8 with just keyboard and mouse
I have been using Digi 003/PTLE8/windows xp , desktop, for sometime...I want to also set up PTLE 8 on my laptop(windows vista),which does not have a firewire 1394 plug insert. ..which i really dont need my digi 003 mix unit for anyway.The keyboard and mouse entry is all i need.....Problem is after a fresh download and install of just the PTLE 8 softwarefrom the "mydigi" On first fire up.. i get the "cant locate hardware" dialog. I hit OK it does nothing,,i hit cancel it closes me out......is their a way too bypass this....so i can use PTLE8 without hardware and just use the keyboard and mouse.
Redchair Recordings
Old 10-04-2009, 03:22 PM
LincolnT LincolnT is offline
Default Re: PT8 with just keyboard and mouse
That is what the MBox 2 Micro is made for: http://digidesign.com/index.cfm?lang...20&itemid=5343
MBox 2 Pro connected to motherboard 4 pin firewire port
Dell Inspiron 9300 laptop
2.0 gHz Pentium M
2 gB ram
Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter
Roland 700SX stage piano
Studio Projects C3 mics
Melodyne Plugin
Dual Boot:
PTLE 8.0.1 on Windows 7 Enterprise 32 bit
PTLE 8.0.1 on XP Media Center SP3
Old 10-04-2009, 03:30 PM
JMS40 JMS40 is offline
You cannot run Pro Tools LE without hardware redchair. It's the ultimate protection dongle. As Lincoln points out, the Micro is the smallest option.
Old 10-04-2009, 03:32 PM
Does Pro Tools LE M Powered work with the 003? If so, that would also work. But Pro Tools M Powered also requires an iLok. And the iLok has no earphone jack.
2.0 gHz Pentium M
2 gB ram
Melodyne Plugin
Dual Boot:
Old 10-04-2009, 03:35 PM
Originally Posted by LincolnT View Post
Does Pro Tools LE M Powered work with the 003? .
PT M-Powered is only for use with M-Audio devices. PT LE is only compatible with Digi hardware.
Old 10-04-2009, 03:37 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Wow
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 10-04-2009, 03:41 PM
Originally Posted by Keybeeetsss View Post
Wow
What's so exciting, Key?
2.0 gHz Pentium M
2 gB ram
Melodyne Plugin
Dual Boot:
Old 10-04-2009, 03:44 PM
Just a bit surprising to see a 4yr user ask this question &/or not know that... butttt
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 10-04-2009, 04:08 PM
strangeLoop strangeLoop is offline
When I bought my 003+ I also bought an MBox 2 Micro and an OWC OTG drive. It is the best deal in town. You can take your editing, sound design or MIDI composing anywhere on any computer. And if you are just doing MIDI composing you don't need an external drive.
Old 10-04-2009, 09:37 PM
scar97 scar97 is offline
Some people say that I'm atarded......
You seem to take your brillance for granted KB..LOL... I think you need to be nice, sit back and we will send you some fruit snacks.
"It aint about the stuff you got..If it sounds right you're finished..Burn it!"
For all complaints click here
DAW
Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent
Mouse and Keyboard Issue Durwoodghib Windows 4 01-30-2011 10:01 PM
Mouse and Keyboard set-up james21789 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-05-2010 05:37 PM
Mouse Keyboard USB vs PS/2 yarrick19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-18-2005 10:57 PM
USB MOUSE/KEYBOARD Abomb97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2003 06:13 PM
Wireless keyboard and mouse Pughjet Sound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-01-2001 08:20 AM
