Trouble with my Axiom 25
Hey everyone, I bought a Axiom 25 and I can not seem to use it with Xpand!. I have it hooked up USB and on my MIDI track I have my input set to ALL, but I dont know where to go from there. I dont know if its a setting in the Axiom or what. Help is much needed.
Thanks |
Re: Trouble with my Axiom 25
Have you created a AUX track and inserted Xpand!? Alternatively, use an Instrument track.
filosofem |
Yeah, I created a AUX track and Audio track. I put XPand on the audio track and I see levels on my MIDI track, but when I record enable both tracks, I cant hear Xpand!. Do you have an idea why that is? Is there a setting on my Axiom or Pro Tools I am missing?
MIDI Output assigned Xpand! 1 Channel 1?
filosofem |
Yeah dude everything you are mentioning, I already did. Today I bought some MIDI cables. Im going to see if this works better, but I wouldnt see why the USB wouldnt work. We will see.
Well That won't work on an Audio track.. It should be an instrument track, put Xpand on that, make sure u have Midi thru checked, & tell us what happens...
Hey Filo (I almost knew I'd see u in here)
Well today, I checked and I have MIDI coming in, but I cant get MIDI out? So as I record enable I see the MIDI IN LED flashing, but no MIDI Out. WHere is the MIDI Thru? Is there any other settings that I have to check?
If u see a midi sig then the midi thru is checked...
So why cant I hear my synth when I record and playback?
We really don't know what ur doing.. I gave u a suggestion as to what to do.. We don't even know if u did that.. U came back with Quote:
Axiom Air 49 with OS X 10.6.8 | djbenedetti | macOS | 1 | 06-21-2013 09:57 AM |
Axiom Pro 49 and Axiom 61, Prepheral issue? | udhoshi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-22-2011 03:45 PM |
Newb having trouble with getting Axiom 61 to work in PT LE | Mohammadstatus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-12-2009 01:07 PM |
Dual screen, Video trouble. Not that kind of a trouble... | 11miles | Pro Tools TDM Systems (Mac) | 1 | 09-25-2009 09:28 AM |
M-Audio Axiom 49 Trouble- Help! | Kemshino | MIDI | 5 | 08-24-2008 02:58 PM |
