Old 03-16-2009, 01:52 PM
mrjk79 mrjk79 is offline
Default Undipped Mix Minus
Hello all,
I am sure this has been discussed in the past, and I have found a couple threads about this subject, but I'm still a bit confused. What would be the best way to create a Mix Minus Narration undipped for Narration while still creating your regular stereo mix?
Thanks for your help!
Old 03-16-2009, 03:18 PM
infiniteloop infiniteloop is offline
Default Re: Undipped Mix Minus
In the M&E aux that you dip under the narration, put a pre-fade send in the channel and send that wherever your undipped MixMinus needs to go.
Old 03-17-2009, 02:39 AM
s0und80y s0und80y is offline
Originally Posted by mrjk79 View Post
Hello all,
Create 2 AuX Busses and send all your music and effects to them both.
Route one of your Music and Effects Aux to your Full Mix Master and one to your Mix minus M+E Master.
Make Sure you have a seperate VO Buss.
Dip only the Music and Effects track that is being sent to the Full mix.
I usually draw in the dips around -8db under a VO.
I Also make sure the undipped M+E sits around -5 to -3 on my VU
This is how I do it on a day to day basis.
HTML code is On
Undipped music stem mwpmorris1 Post - Surround - Video 48 04-16-2018 07:20 AM
M&E's dipped or undipped? c-post Post - Surround - Video 3 12-23-2006 12:08 PM
Creating different mixes-dipped, undipped, etc. evann Post - Surround - Video 1 07-30-2005 07:34 PM
undipped meaning poldo Post - Surround - Video 4 06-14-2005 01:41 AM
