Upgrade to PT8 = Low levels?
Hello all,
I recently upgraded to Protools 8 HD from Protools 6.9 HD, and now I'm getting a lot lower of a level coming into Protools via 192io. I made sure I was using the same input trims I was using before, but now I've got my preamp turned all the way up and still getting a lot less signal than usual. Has anyone else experienced this? Could there be a setting that I am missing somewhere? Any help is appreciated! |
Re: Upgrade to PT8 = Low levels?
I upgraded from PT 7.4 and everything's fine.
And check that your input levels are set to +4 on your 192 Cheers N |
Input levels are at +4. I'd rather not downgrade back to 6.9, but I am getting unusable signals coming in from equipment that worked great before.
Could this be a coincedence and my db25 cable went bad? The digi link cable also? I have two 882s also, are they handled differently in pt8? I'm getting great signal from the Adat in from my digimax... |
It ended up being the db25 cable... thanks for the replies!
Tracking Levels and Playback Levels | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-26-2010 05:37 PM |
Creating the best mix levels / playback levels | universe777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-25-2006 10:49 PM |
Broadcast levels vs. Podcast levels... | McBoob | Post - Surround - Video | 0 | 05-05-2006 08:03 AM |
Linking track levels w/ pre-fader bus levels? | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-07-2003 10:36 PM |
Mix levels vs. monitor levels | badshirt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-05-2001 12:17 AM |
