Old 08-14-2008, 07:23 AM
15yearsonptools 15yearsonptools is offline
Default Midi mic pre control
Question about MIDI mic pre control.
I have three rooms sharing one 8 channel Grace mic pre. I'd like to be able to switch (easily) which system is controlling the mic pre. I thinking either a analog switch (I haven't been able to find a pre made midi switch, but I'm pretty sure I could McGyver something) or something fancy from 'Midisolutions.com'. The guy from MIDI solutions has asked if there is any reason the MIDI output from all three rooms should not be connected all the time. Does anyone know if this will be a problem? Or if anyone has a smart idea..
thanks
Old 08-14-2008, 07:49 AM
DigiTechSupt's Avatar
Default
What kind of MIDI interface are you using in each room to send MIDI data to the Grace?
I wouldn't think having them all connected simultaneously would be a problem. Using a merge box (3x) may be a very simple, easy solution.
Avid Audio Tech Support
Support FAQ
Old 08-14-2008, 08:56 AM
Default
MOTU midi express and two MOTU fastlane interfaces.
So just the midi merge on the output right? It's pretty important that accidental level adjustments from the other rooms don't happen!
Thanks for responding.
Old 08-14-2008, 10:20 AM
Default
If accidental level adjustments are a concern, then a switch would be the better way to go.
New you can get ones like:
http://www.philrees.co.uk/products/selector.htm
or use a programmable one like the MIDI Express XT (I think the MIDI Express is programmable, too..)
or go used with something like:
http://cgi.ebay.com/Kawai-Mav-8-Midi...=1218734367788
The outputs of each of your consoles/controllers would go into the MIDI interface/patchbay/switch and you would use that to control which console/controller has it's MIDI output routed to the Grace.
Support FAQ
Old 08-15-2008, 11:14 AM
Default
Awesome. Thanks. I've out a bid on the Kawai. I was looking for the phil res product you mentioned but I haven't had any luck with that. I really appreciate your help.
Aaron
midi issue- can see midi signal but cant's control Xpand2 macroniche Pro Tools 10 1 08-02-2012 12:16 AM
Pro Control mapping for midi control? michael c ProControl, Control|24, Command|8 0 04-06-2007 12:36 PM
Evolution U-Control midi control surface eddie v MIDI 0 03-22-2004 03:53 PM
MIDI Machine Control out of control zenbarai Post - Surround - Video 3 04-19-2002 07:08 AM
Control PT recording features via MIDI from an extenal MIDI device Montxo MIDI 3 05-05-2001 08:05 AM
