Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 08-12-2008, 02:49 AM
Default "Send via digidelivery" from PT7.4cs6 does not work
Has someone noticed this?
I´m running ProTools7.4cs6 on OSX10.4.9.
"Send via Digidelivery" from PT brings up the Digidelivery client without an upload task. It just starts the client and that´s it.
Happens on all of my 4 systems.
It used to work fine with PT7.3.1
Can someone confirm this?
Thanks,
frank.
"Tuner" and internal "DSP" doesn't work on Mbox 3 Pro luckydjacks FireWire & USB Audio Interfaces (Win) 129 06-20-2014 03:25 AM
Why send tracks to hardware outputs instead of "Master" track/bus? gopher Getting Started 11 01-03-2014 12:12 PM
"Rig balancing" and "RIG VOL" does not work anymore... Mitchflappi Eleven Rack 3 06-20-2012 01:16 PM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin macOS 3 04-01-2012 04:43 AM
MIDI "program change" send=buffer overflow on target triplex Pro Tools TDM Systems (Mac) 5 09-01-2010 03:14 AM
